Ford Puma Discuss the Ford Puma here!
What will fit
Old Aug 13, 2012 | 11:44 AM
s6boy1979's Avatar
s6boy1979
Default What will fit
Just got myself a Puma 1.7 2000 X reg.
I have read a few times that fez parts are a direct fit, so i am wondering what parts will fit and what mk fez do i need to get the bits off?
Old Aug 13, 2012 | 12:21 PM
Dal_'s Avatar
Dal_
What parts do you need to know about?
Old Aug 13, 2012 | 12:51 PM
s6boy1979's Avatar
s6boy1979
Suspension, exhausts, engine parts and brakes
Old Aug 13, 2012 | 12:54 PM
Dal_'s Avatar
Dal_
The nearest Fiesta will be the Mk4/5 Fiesta Zetec S of the same age (97-01) although most parts are the same - brakes, the 1.6 engine, etc, the exhaust is different (the Puma one is slightly longer) and the suspension is different too.
Old Aug 14, 2012 | 11:16 AM
s6boy1979's Avatar
s6boy1979
Ok thanks
Old Aug 14, 2012 | 11:57 AM
PumaJay's Avatar
PumaJay
anti roll bar is also thicker on a zetec s and that will fit on the puma, but apart from that the puma bits are generally better
Old Aug 14, 2012 | 12:00 PM
s6boy1979's Avatar
s6boy1979
Ok cool, was just thing about cost as it is my second car and my daily drive so didnt want to spend loads on parts
Old Aug 14, 2012 | 12:05 PM
PumaJay's Avatar
PumaJay
then my advice to you is to flaunt what the puma does best, handle, if the bushes are looking tired then invest in some powerflex ones and fit the omp lower front strut brace, will totally transform the car apart from that just enjoy driving it there great little cars!
if you want more on the braking side of things then a 300mm brake conversion will go under the 15" wheels if you shave a small amount of the caliper and the work brilliantly.
Old Aug 14, 2012 | 12:20 PM
s6boy1979's Avatar
s6boy1979
Are the spacers worth it?
Old Aug 14, 2012 | 12:25 PM
PumaJay's Avatar
PumaJay
if you mean the rear beam spacers then yes, 12.5mm or 20mm are the best bets, easy enough to fit aswell, its all about little tweaks with puma's if you start fitting coilovers and other various bits then you kind of have to keep going with them, best bet is to keep it simple, especially if its your run around.
sometimes i wish i hadnt turned mine into a track car lol
Old Aug 14, 2012 | 12:33 PM
s6boy1979's Avatar
s6boy1979
Thanks for this, will i be ok with just a set up uprated springs as well? Mine may end up as a track toy one day
Old Aug 14, 2012 | 04:19 PM
PumaJay's Avatar
PumaJay
yeh decent set of springs, 40mm max i would recommend and you'll have the best of both worlds with handling and ride comfort
Old Aug 14, 2012 | 05:46 PM
s6boy1979's Avatar
s6boy1979
Cool beans, cheers
Old Aug 15, 2012 | 11:43 AM
PumaJay's Avatar
PumaJay
no probs, any other problems just drop me a pm
Kyle Langford
27
Aug 5, 2019 07:54 PM
ekjim
Aug 27, 2015 05:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
marky_g
Aug 15, 2015 10:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
