Who's using "over skimmed" YB head
Old Aug 6, 2012 | 12:16 PM
Ridgey's Avatar
Ridgey
Default Who's using "over skimmed" YB head
Just curious who is running YB head that is thinner than 138.5mm ?
Would i be mad to consider using a 137.8mm head with:
pocketed pistons (valve cut outs)
standard cams
grp A head gasket
what are the potential consequences?
slightly higher compression (det ?)
valve seat integrity
thanks
Old Aug 6, 2012 | 12:55 PM
saph4be's Avatar
saph4be
When I removed mine it was
Old Aug 6, 2012 | 01:57 PM
Ridgey's Avatar
Ridgey
The thin head only came out of the car when a spark plug tip melted and scored a cylinder and crank due to running lean i believe.
Old Aug 6, 2012 | 03:02 PM
750hp escos's Avatar
750hp escos
Seen many heads as low as this so no worries..
cheers danny
Old Aug 6, 2012 | 03:14 PM
dave cos4x4's Avatar
dave cos4x4
you can use a thicker gasket Dave.
Old Aug 6, 2012 | 03:18 PM
Ridgey's Avatar
Ridgey
Dave
Do you mean multi layer metal type?
If so i'd probably have to get the head skimmed again for it to be ready for that type of gasket
Old Aug 6, 2012 | 03:40 PM
joffy's Avatar
joffy
SLOW LEARNER
in your first post you have put slightly lower compression? Might be wrong but with a skimmed head wont the compression ratio be higher?
Old Aug 6, 2012 | 03:41 PM
costina's Avatar
costina
Live long and prosper!!
Is'nt there issue with squish and if you start porting a over skimmed head.
Sure theres a very long thread on here about squish and the effects.
Why would ford/cosworth give the 138.68mm measurement for some Fred in the shed to say thats ok bud u can go to 138 and more.
Ridgey get some correct advice before you make your descision
Old Aug 6, 2012 | 03:54 PM
Rollinz's Avatar
Rollinz
Surley this mainly depends on stroke/rod legnth/ piston hight
And then down to mapping rather than anything else?
Old Aug 6, 2012 | 04:03 PM
fraser9764's Avatar
fraser9764
i thought the main problem with this is the lack of material left around the valve seat.
Stu did a good post on it a while back.
Did you find any faults with your old head/gasket Dave?
Old Aug 6, 2012 | 04:07 PM
fraser9764's Avatar
fraser9764
found it
https://passionford.com/forum/genera...limit-why.html
Old Aug 6, 2012 | 04:11 PM
750hp escos
The cr will change so obviously the map would need a tweak depending on how close your map is in the first instance..
As for porting that wont have any effect on the heads depth..
Its not ideal to run a head thats skimmed to depth but on an engine of your spec it will be fine..
Back in the day when works teams starting raising cr the actually started to skim the heads lower than yours just to get the cr up!!!
Ive seen a few perfectly good heads skimmed to 137,7 just to get the disered 9.1 cr they needed!!
cheers danny
Old Aug 6, 2012 | 04:31 PM
750hp escos
Originally Posted by fraser9764
Interesting thread that can at least shy people away from spending good money on maybe not such a good head..
If you have an engine that has been fine and you need to do a gead gasket or similar and find your heads under the 138.6 then there really isnt any worry..just re fit,its very unlightly to go wrong seeing as it hasnt already..
If your doing and big power engine build then find the best you can but these days id say anything over 138.5 is a result..
Niel roper and others im sure can drop valve seats and the like also so can save another life there
cheers danny
Old Aug 6, 2012 | 05:57 PM
Miller 3's Avatar
Miller 3
I was just about to say about getting the valve seat lowerd.
Old Aug 6, 2012 | 06:59 PM
Ridgey's Avatar
Ridgey
joffy: I ment to put Higher comp in my first post.
The original engine with this head showed that the valves had touched and marked the pistons. So it would seem reasonable that head depths were physically dicated by a mechanical interferance issue which on a standard engine with standard pistons would be valve clearance.
As well as the impact of higher CR which will be some what offset by the material removed from the valve cut outs and my current setup has valve cut outs.
I have seen the thread about valve seats, however, is this big power engines running high lift CAMS? double valve springs etc, as that would put far more material stress on the seat.
Graham: Head gasket looked OK mate, but i don't want to put that head back on (always leaked water around the exhaust ports), so i'd like to use this other one.
Old Aug 6, 2012 | 07:42 PM
richard youll's Avatar
richard youll
I am and it's a lot less than that too.!
Old Aug 6, 2012 | 08:00 PM
botters's Avatar
botters
competant bodger
you can get the valve seats staked to stop them falling out
Old Aug 7, 2012 | 06:19 PM
Ridgey's Avatar
Ridgey
anyone else?
Old Aug 7, 2012 | 11:46 PM
richard youll
My head is skimmed right into the valve seats , I've not recessed them or anything, it's running 460 bhp dyno'd with nitrous (400 nitro jet and can't remember the fuel jet) I kick its head in everywhere and done 3 track days one of which it was borrowed for the lancs rs show at Anglesey and was driven hard by 3 people giving passenger rides all day non stop never let me down once!
Old Aug 8, 2012 | 05:31 PM
foreigneRS's Avatar
foreigneRS
Testing the future
get karl norris' opinion on this, he is extremely knowledgeable and experienced in such matters
Old Aug 10, 2012 | 10:22 AM
costina's Avatar
costina
i've not yet seen one 205 blocked engine without valve marks in the pistons inlet side. either down to over reving or timing it up like a pinto.
As said above is the best advice as all tuners have there way of doing things.
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
