Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Minimising roof Condensation
Old Jul 30, 2012 | 08:52 AM
slammedorion's Avatar
slammedorion
Default Minimising roof Condensation
My concrete section garage is 10x20.
A few years back I put a new metal roof on it, it's lovely and water tight.
When winter comes it freezes on the underside, when it starts to melt I may aswell have the car outside!
I'm now off for 2 weeks from work and wanna try minimise this issue.
Do I use the kingspan boards
Or theres silver bubble wrap stuff on a roll I could stick to it
Or do I use alittle timber between the beems and put a false celling in with plaster board and fill with loft insulation?
I know I ain't gonna fully stop it, just wanna minimise it.
A mates used the kingspan boards with excellent results.
Old Aug 2, 2012 | 11:53 AM
Brendan's Avatar
Brendan
struggling with reality
silly question !!! is the garage normally heated?
Old Aug 2, 2012 | 12:14 PM
sicosnutter's Avatar
sicosnutter
you need air movement extractor fan bringing air in one end and another taking air out the other end.
Old Aug 16, 2012 | 10:29 AM
slammedorion
No
Old Aug 19, 2012 | 08:19 AM
drive me crazy's Avatar
drive me crazy
There is no real sulution to this ive tried most things you will get condensation whatever you put up there the wriggly tin or box profile the water will run downthe cavity where the profile and the kingspan dont connect if its flat steel then it will work false ceiling will only hide it so whatever you do dont use plasterboard ext ply if you are doing that dont bother with that anti-condinsation paint expensive rubbish only helps a bit will 10 times worse if you use a heater in there the answer now is if anyone is putting up a tin roof get the factory insulated sheets the only thing i havnt tried is if you put boards on the underside of the beams and use expanderble foam to fillthe cavity that i think would workif you try that let us now.
Old Aug 23, 2012 | 09:31 PM
New Shell Dude's Avatar
New Shell Dude
I had the same prob. A small air vent in each end sorted it.
A.t.p
Sep 29, 2015 05:04 PM
oldskooldanrst
Sep 27, 2015 04:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 22, 2015 06:38 PM
Neil Clark
Sep 8, 2015 07:06 PM
