Swirl Pot Setup on FRS
Old Jul 10, 2012 | 04:38 PM
thielt1's Avatar
thielt1
Default Swirl Pot Setup on FRS
Does anyone have a diagram or detailed pictures for their swirl pot setup on an FRS? Thanks!!!
Old Jul 24, 2012 | 02:02 PM
thielt1's Avatar
thielt1
anyone?
Old Jul 25, 2012 | 09:19 PM
nevsrevs's Avatar
nevsrevs
got this one..
044 fuel pump, being pumped out with o.e. pump
Old Jul 25, 2012 | 09:22 PM
nevsrevs's Avatar
nevsrevs
and this one,
Old Jul 26, 2012 | 04:57 PM
thielt1's Avatar
thielt1
Thanks for the reply!
Can I pipe AN fittings into the original tank?
Also what bosh pump would I use for the pickup that can use AN fittings?
Old Jul 26, 2012 | 05:06 PM
nevsrevs's Avatar
nevsrevs
its going to be hard to use AN fittings onto o.e. pump as there on speed clips standard. as for lift pump we are just using a walbro foucus pump.. as the 044 does the hard work...
Old Jul 26, 2012 | 05:14 PM
thielt1's Avatar
thielt1
What I meant with the AN fittings with the standard tank was can they be bonded into the OEM cover or does something else have to be made internally to pick up the fuel?
Love your car by the way!
Old Jul 26, 2012 | 05:28 PM
nevsrevs's Avatar
nevsrevs
not with you there mate? the flow comes up from the bottom of the tank into the pump, then out the top hat that you can see in the pics, its all 1 unit..
nevsrevs's Avatar
nevsrevs
cheers about the car too, yours is coming on well..
Old Jul 26, 2012 | 05:38 PM
thielt1's Avatar
thielt1
Ok, I see what you are saying. I am going to take a look at it again tonight. Thanks for your help!
(there were two FRS's in Fast ford recently one had orange compomotive wheels and the other was Dhyllan's car which are running setups close to the one I want to put in.)
Old Jul 26, 2012 | 05:58 PM
AlexRS2782's Avatar
AlexRS2782
The Mk1 with the orange MO6's was SteveB's - he's on here :thumbsup:
https://passionford.com/forum/members/66-steveb.html
Old Jul 26, 2012 | 06:53 PM
thielt1's Avatar
thielt1
Thanks! I just contacted both of them to see if we can get some more pics and details.
Old Jul 26, 2012 | 06:58 PM
SteveB's Avatar
SteveB
I'll answer tomorrow when I have more time and access to PC (on phone ATM)
Old Jul 27, 2012 | 10:42 AM
SteveB's Avatar
SteveB
What exactly do you need to know??? I haven't got any pics but can give a detailed description if that helps at all inc wiring the 044 seperatly from the Ford system
Old Jul 27, 2012 | 12:21 PM
thielt1's Avatar
thielt1
I think the detailed description would help out a lot.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
