Swirl Pot Setup on FRS
Old 10-07-2012, 04:38 PM
thielt1
thielt1's Avatar
Default Swirl Pot Setup on FRS
Does anyone have a diagram or detailed pictures for their swirl pot setup on an FRS? Thanks!!!
Old 24-07-2012, 02:02 PM
thielt1
thielt1's Avatar
anyone?
Old 25-07-2012, 09:19 PM
nevsrevs
nevsrevs's Avatar
got this one..
044 fuel pump, being pumped out with o.e. pump
Old 25-07-2012, 09:22 PM
nevsrevs
nevsrevs's Avatar
and this one,
Old 26-07-2012, 04:57 PM
thielt1
thielt1's Avatar
Thanks for the reply!
Can I pipe AN fittings into the original tank?
Also what bosh pump would I use for the pickup that can use AN fittings?
Old 26-07-2012, 05:06 PM
nevsrevs
nevsrevs's Avatar
its going to be hard to use AN fittings onto o.e. pump as there on speed clips standard. as for lift pump we are just using a walbro foucus pump.. as the 044 does the hard work...
Old 26-07-2012, 05:14 PM
thielt1
thielt1's Avatar
What I meant with the AN fittings with the standard tank was can they be bonded into the OEM cover or does something else have to be made internally to pick up the fuel?
Love your car by the way!
Old 26-07-2012, 05:28 PM
nevsrevs
nevsrevs's Avatar
not with you there mate? the flow comes up from the bottom of the tank into the pump, then out the top hat that you can see in the pics, its all 1 unit..
nevsrevs
nevsrevs's Avatar
cheers about the car too, yours is coming on well..
Old 26-07-2012, 05:38 PM
thielt1
thielt1's Avatar
Ok, I see what you are saying. I am going to take a look at it again tonight. Thanks for your help!
(there were two FRS's in Fast ford recently one had orange compomotive wheels and the other was Dhyllan's car which are running setups close to the one I want to put in.)
Old 26-07-2012, 05:58 PM
AlexRS2782
AlexRS2782's Avatar
The Mk1 with the orange MO6's was SteveB's - he's on here :thumbsup:
https://passionford.com/forum/members/66-steveb.html
Old 26-07-2012, 06:53 PM
thielt1
thielt1's Avatar
Thanks! I just contacted both of them to see if we can get some more pics and details.
Old 26-07-2012, 06:58 PM
SteveB
SteveB's Avatar
I'll answer tomorrow when I have more time and access to PC (on phone ATM)
Old 27-07-2012, 10:42 AM
SteveB
SteveB's Avatar
What exactly do you need to know??? I haven't got any pics but can give a detailed description if that helps at all inc wiring the 044 seperatly from the Ford system
Old 27-07-2012, 12:21 PM
thielt1
thielt1's Avatar
I think the detailed description would help out a lot.
timsrs
13-11-2018 11:48 AM
01-11-2015 06:53 PM
Fezman1
02-10-2015 01:22 PM
SMILER258
28-09-2015 09:04 AM
IainRS1700T
25-09-2015 06:44 AM
Quick Reply: Swirl Pot Setup on FRS
