which rotary polisher
Old Jul 9, 2012 | 09:31 PM
killa_paul's Avatar
killa_paul
Default which rotary polisher
Hi chaps
im looking to get a rotary polisher / buffer
this is for use on a freshley painted sapphire for waxing / finishing
and a mg midget that needs a good mop and polish then wax
any ideas on which is is good polisher and pads to use
and the best products to use them with ...
whats the below one like
thanks paul
http://www.ebay.co.uk/itm/Dodo-Juice...item1e6adbbb56
Old Jul 9, 2012 | 09:39 PM
H7 CYA's Avatar
H7 CYA
Firsty how fresh is the paint on the saph? You shouldnt really be using a machine on fresh paint.
The dodo one you posted has good reviews on dw etc. I bought a silverline rotary as the next step up from my da. quite a heavy machine but works really well. I take it you have done this type of thing before?
Also what colour are both the cars?
Jaimi
Old Jul 10, 2012 | 01:48 AM
killa_paul's Avatar
killa_paul
[QUOTE=H7 CYA;5970344]Firsty how fresh is the paint on the saph? You shouldnt really be using a machine on fresh paint.
The paints about 8 months old but the car has been stored in a car coon and not left out in the weather,
I take it you have done this type of thing before? nope im a novice with machine polishing
my sapphire is a mercury grey
and the mg is british racing green ....
thanks
Paul
Old Jul 10, 2012 | 02:17 AM
Rsmat's Avatar
Rsmat
If I was you as a novice I'd try a DA polisher first mate.
Old Jul 10, 2012 | 05:10 AM
bluntys1rsturbo's Avatar
bluntys1rsturbo
Boost addict
try something like the kestrel das6
Old Jul 10, 2012 | 12:22 PM
opposite lock's Avatar
opposite lock
Sim 180 rotary at entry level prices but it is heavy . Das 6 for a DA .
Old Jul 10, 2012 | 01:44 PM
Brian's Avatar
Brian
I started with a silverline rotary but that packed up so i bought a Dodo Juice Pro machine and its awesome
Brian
Old Jul 10, 2012 | 01:50 PM
Brian's Avatar
Brian
You seen this not a kit just the machine http://www.ebay.co.uk/itm/dodo-juice...b#ht_500wt_954
Brian
Old Jul 10, 2012 | 07:58 PM
killa_paul's Avatar
killa_paul
Where from and have you got a model number ?
cheers
Old Jul 10, 2012 | 08:07 PM
H7 CYA's Avatar
H7 CYA
Have to agree a da will be your best bet. This way you will gain knowledge and corret technique. Also get great results if used with the correct polish/ pad. I started with the kestrel dad 6 pro, stay away from the normal one as it doesn't have much torque and Boggs down easily.
Old Jul 10, 2012 | 08:14 PM
H7 CYA's Avatar
H7 CYA
Got mine from i4 detailing in a mezerna kit.
Old Jul 11, 2012 | 04:25 AM
killa_paul's Avatar
killa_paul
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=130600041200 anyone ?
Old Aug 8, 2012 | 10:19 PM
JamesR1's Avatar
JamesR1
Anybody for a brew?
DA is safe and will achieve same results will just take a bit longer.
DAS6 is very good, g220 is also good just more expensive.
Old Aug 13, 2012 | 08:53 PM
opposite lock
I found the g220 DA to have a big 'kick' compared to the das6 . i prefer the later its much more comfortable imo.
steve.rst
Mar 15, 2016 08:01 AM
Mc5506
Oct 5, 2015 09:57 PM
caprixpack
Sep 25, 2015 07:53 PM
timsrs
22
Sep 24, 2015 08:14 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
