which rotary polisher
Hi chaps
im looking to get a rotary polisher / buffer this is for use on a freshley painted sapphire for waxing / finishing and a mg midget that needs a good mop and polish then wax any ideas on which is is good polisher and pads to use and the best products to use them with ... whats the below one like thanks paul http://www.ebay.co.uk/itm/Dodo-Juice...item1e6adbbb56 |
Firsty how fresh is the paint on the saph? You shouldnt really be using a machine on fresh paint.
The dodo one you posted has good reviews on dw etc. I bought a silverline rotary as the next step up from my da. quite a heavy machine but works really well. I take it you have done this type of thing before? Also what colour are both the cars? Jaimi |
[QUOTE=H7 CYA;5970344]Firsty how fresh is the paint on the saph? You shouldnt really be using a machine on fresh paint.
The paints about 8 months old but the car has been stored in a car coon and not left out in the weather, The dodo one you posted has good reviews on dw etc. I bought a silverline rotary as the next step up from my da. quite a heavy machine but works really well. I take it you have done this type of thing before? nope im a novice with machine polishing Also what colour are both the cars? my sapphire is a mercury grey and the mg is british racing green .... thanks Paul |
If I was you as a novice I'd try a DA polisher first mate.
try something like the kestrel das6
Sim 180 rotary at entry level prices but it is heavy . Das 6 for a DA .
I started with a silverline rotary but that packed up so i bought a Dodo Juice Pro machine and its awesome
Brian |
You seen this not a kit just the machine http://www.ebay.co.uk/itm/dodo-juice...b#ht_500wt_954
Brian |
Originally Posted by RS_matt
(Post 5970457)
cheers |
Have to agree a da will be your best bet. This way you will gain knowledge and corret technique. Also get great results if used with the correct polish/ pad. I started with the kestrel dad 6 pro, stay away from the normal one as it doesn't have much torque and Boggs down easily.
Got mine from i4 detailing in a mezerna kit.
DA is safe and will achieve same results will just take a bit longer.
DAS6 is very good, g220 is also good just more expensive. |
I found the g220 DA to have a big 'kick' compared to the das6 . i prefer the later its much more comfortable imo.
© 2024 MH Sub I, LLC dba Internet Brands
