Breaking XR2 Turbo - ERST, Cosworth Management, Roll Cage etc
Group A Ramair filter £30
2 x ERST dizzys £25 each
Escos front brake conversion (fiescosdan) escos calipers and discs with conversion bracket, aso r2k discs new, on xr2 hubs £250
mint xr2 boot lid in white with transit lock and key, heated screen and wiper motor etc £40
Steering rack xr2 £20
Tatty rad and fan (erst maybe?) £20
Heater matrix £20
Home made xr2 side exit (jasonxr2racer made it I think) £30
Gearbox carrier £20
4 x 1ltr silkolene gbox, brand new £40
Single mk2 fiesta carbon fibre door card £40
well used universal front mount intercooler and selection of silicon hoses £30
braided turbo oil feeds £10 each
Fiesta Mk2 XR2 Loom £40
Fiesta Mk2 Xr2 Header tank / washer tanks with pumps £10 each posted or £20 for all 3
Selection of water hoses from Escort Rs Turbo powered XR2 £15
Selection of XR2 interior parts £15
May have some smaller parts hanging around, so just ask here
Ross
Heater matrix £20
Gearbox carrier £20
Ross
What would you consider more realistic? Includes everything ready to go, pectal board and chip, modified efi inlet, dark green injectors, okc phase sensor setup, gadgets crank sensor setup, iscv, tps, polished cossie throttle body, throttle cable mod with shorter cable, 3 bar map sensor, ignition amp, vacuum pipe setup etc
hiya its not being broken until engine and management are sold, if i get no takers ill just leave it in the garage and finish it eventually, i have a long list of people waiting for most of the other parts on another forum lol
Shell is nearly ready to go, with v5 in my name, full XR shell, come with a tailgate and glass and I may leave the loom in if I can't be bothered to take it out.
Will need new front panel unless your using a front mount intercooler and morettes, also rear arches are rotten and have had a really shite looking repair at some point in its life. Front arches etc are good.
Come on caster wheels as pictured, so you will need to being a couple of bodies and maybe some skates incase a wheel breaks lol
£100 collected
Please note Brake servo etc wont be on the shell, just haven't taken them off yet
£100 collected
saph in dorset
Aug 14, 2015 10:10 AM
Aug 14, 2015 07:29 AM
Cameron
14
Aug 9, 2015 06:28 AM
