ST170 "pinking"
Old Jun 30, 2012 | 05:30 AM
STeve's Avatar
Super Moderator
Default ST170 "pinking"
I have never come accross this before on a duratec or zetec for that matter, my mate just bought a really nice st170 and noticed it on the drive home, its drives and pulls well through the gears but when changing up under load he gets pinking until it reaches 2500 revs, I could only suggest using higher octaine fuel, plugs, leads and coil pack, he has in the last week changed the lot and his one still does it, any ideas on where I can tell him to go next as I was thinking the AFM
Old Jun 30, 2012 | 05:33 PM
danme1987's Avatar
danme1987
Is it making a noise? The ST170 i known for a flat spot in the rev range around 2500k. Can be sorted with a remap though.
Old Jul 1, 2012 | 06:22 PM
kyle_st200's Avatar
kyle_st200
Mines got a flat spot at 2500 but if I run it on super it's fine. Didn't have it when I first bought it just started one day
Old Jul 2, 2012 | 08:26 PM
STeve's Avatar
Super Moderator
the only fault he has is pinking which fades out as he goes through the revs, never seen this before on one of these engines, in the old days it was a timing issue but on these engines its pre set with no alteration
Old Jul 14, 2012 | 04:28 PM
gunmetalgrey's Avatar
gunmetalgrey
Hi,
I cant help with this problem of your mates, but my st has exactly the same problem. As you im at a loss as to what is causing it, the only thing i was going to try was to clean or replace the MAF sensor??
My st even pinks on the overrun!! Its an 03 and runs superbly otherwise..
Apologies, re-read your post again and noticed the MAF is on your list to do also.
Chris.
Old Jul 14, 2012 | 08:39 PM
STeve's Avatar
Super Moderator
I own a ST myself so the plan is for him to try my maf etc and see if it cures it
Old Jul 14, 2012 | 09:04 PM
gunmetalgrey
Ok, be great if you post up the results, id love to know what causes the pinking on mine.
Chris.
Old Jul 14, 2012 | 09:15 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
if its done more than 60k change both lambdas for new genune ones
Old Jul 26, 2012 | 11:58 AM
borinous's Avatar
borinous
did this get sorted out? as mine is very simular to this and ive recently had EML on so im thinking Lambdas?
Old Jul 29, 2012 | 03:16 PM
STeve's Avatar
Super Moderator
spoke to him yesterday and he says hes been saving to buy them as they were expensive, so once fitted I will update the thread
Old Jul 30, 2012 | 07:37 AM
borinous's Avatar
borinous
Nice one cheers mate
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Andypandy260
Sep 23, 2015 10:28 PM
pie-face
Sep 15, 2015 10:43 AM
