tuning a escos t25? suggestions please????
Old Jun 14, 2012 | 08:01 PM
alex2012's Avatar
alex2012
Default tuning a escos t25? suggestions please????
hi basically im looking into tuning my escos the car is running all standard management but at the moment has a stage 1 chip rs500 big intercooler uprated fuel pump airfilter full decated staineless t3 hybrid turbo i also stripped the engine right down all new gaskets group a head gasket so engines good for little more power run her up the quarter mile and run a 13.3 at 100mph not bad for 14psi boost so want to run 350ish bhp and high 12s quarter mile whats your suggestions??
Old Jun 14, 2012 | 08:13 PM
botters's Avatar
botters
competant bodger
convert to l8 managment then the world is your oyster as far as im aware the t25 escorts managment is limited to around 300 ish bhp after that it gets difficult/ exspensive to tune
Old Jun 15, 2012 | 07:58 AM
alex2012's Avatar
alex2012
Hi yeah this is what I was thinking i need to find Someone who has done this and can make me a list of what's needed to do this I'm mechanic and had my cossie apart to many times but wires ain't my strong point inless I have it in black and white in stuck.
Old Jun 15, 2012 | 08:34 AM
Danwood79's Avatar
Danwood79
Ask on here they should help you http://www.escortrscosworth.com/forum/index.php
Dan
Old Jun 15, 2012 | 08:53 AM
JamesH's Avatar
JamesH
Put it on aftermarket management
Old Jun 15, 2012 | 09:07 AM
joffy's Avatar
joffy
SLOW LEARNER
Speak to MSD
Old Jun 15, 2012 | 11:41 AM
ECOS95's Avatar
ECOS95
2nd that.
Don't fit the old cossie stuff that's probably seen better days. Things have moved on since the 1980's.
Speak to MAD re a management swap.
Old Jun 18, 2012 | 08:51 AM
phs84's Avatar
phs84
https://passionford.com/forum/ford-e...-cossie-5.html
my small turbo cossie runs on haltech ps 1000 and t35.63!
Old Jun 18, 2012 | 10:09 AM
alex2012's Avatar
alex2012
Ok what sort of horse power do you run? And if you want to up horse power later is it easy todo so?
Old Jun 18, 2012 | 10:43 AM
Nick.W's Avatar
Nick.W
Here is a picture shamelessly taken from a similar thread on here.
This is what you need
Old Jun 18, 2012 | 10:59 AM
Paul_RS's Avatar
Paul_RS
You can map them to have over 300bhp. My friends had his mapped at NMS on a hybrid T28 and it was over 300bhp. Pretty sure Turbosystems and MSD can map EECIV too. MSD was developing a T34 conversion for them a while back.
Old Jun 18, 2012 | 11:05 AM
JamesH's Avatar
JamesH
Originally Posted by ECOS95
2nd that.
Spot on
Old Jun 19, 2012 | 06:21 AM
alex2012's Avatar
alex2012
I like the sound of sierra or earlie escos management due to owning a sierra which was dirt cheap and very easy to tune! One of my friends runs a after market management and is having quite a few problems think its a omex
Old Jun 19, 2012 | 06:41 AM
JamesH's Avatar
JamesH
Do you mean you have a donor car to rob all the bits off? If not, it will soon add up, especially if you're going wasted spark etc. upto you but I'd definitely do the aftermarket
Old Jun 19, 2012 | 09:55 AM
alex2012's Avatar
alex2012
No don't have donor car but was looking my t3 will handle 350 so will only need engine loom Ecu injectors map sensor throttle body and couple of small sensor looking around Ł500 for good second hand
Old Jun 19, 2012 | 10:38 AM
phs84's Avatar
phs84
msd never finished the t34 conversion.
with an aftermarket ecu you can do anything you want and you use the "better" htt inlet manifold.
mine is about 360 at the moment and i´ve no probs with it.
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
gcfcos
59
Oct 6, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
Si B
Sep 12, 2015 06:49 AM
Mickeystewart
Sep 9, 2015 04:04 PM
