BMW E46 Servicing
Old Jun 12, 2012 | 08:47 PM
Westy's Avatar
Westy
Default BMW E46 Servicing
On the dash on the car it says inspection, 500 miles. This means that it was due a service 500 miles ago I presume. If I take it to a local garage (not BMW) and get them to change oil etc.. Will they be able to stop this inspection thing coming up everytime I start the car?
To be fair the car has full BMW service history but can't be arsed to pay BMW prices as in the long run it probably isn't worth the extra.
Thanks
Old Jun 12, 2012 | 08:59 PM
LHD220Turbo's Avatar
LHD220Turbo
any decent garage can reset the service indicator, its only a matter of plugging in a scanner tool (snap on etc) and reset it
Old Jun 12, 2012 | 09:10 PM
Westy's Avatar
Westy
Great.. Cheers for that. Suppose I should just mention it when I drop it off lol
Old Jun 12, 2012 | 09:14 PM
imnoteasy's Avatar
imnoteasy
you dont need any tools to reset the timer, its all done with the key and switches,
Old Jun 12, 2012 | 09:35 PM
Brendan's Avatar
Brendan
struggling with reality
a positive fires means that many miles till service due a negative figure mes past service!
Old Jun 12, 2012 | 09:43 PM
cossiestu's Avatar
cossiestu
Try bimmerforums, I found various ways on there, of resetting/turning stuff on or off, by key turns etc. Pretty sure it included knocking out service lights....
Old Jun 12, 2012 | 10:04 PM
Westy's Avatar
Westy
I do actually want it serviced and not just the light knocked off. I'm sure they will be capable of sorting it...
It's a minus so due.
Don't miss the type r at all.. These cars are completely different and for all the right reasons.
Old Jun 13, 2012 | 12:00 PM
RC4's Avatar
RC4
what kind is it pal?318,320,325???
try and get them codes to do different things as above theres loads on bimmer forums
Old Jun 13, 2012 | 12:11 PM
martysmartie's Avatar
martysmartie
This in most cases (Usually the trip reset button is used), although it can also be done via OBD (i.e. computer) which is most likely what the dealer would do but everyone else would just use this combo.
I would have thought it would mean 500 miles until the service is due, then a minus figure thereafter, not owning a modern car it's just a guess?
Martin
Old Jun 13, 2012 | 12:49 PM
Jim Galbally's Avatar
Jim Galbally
an inspection 1 is more than just a "normal" service, make sure any garage that does it sticks to the BMW service schedule, details will be in your service manual. just an oil and filter change won't cut it.
Old Jun 13, 2012 | 12:51 PM
Jim Galbally
BMW Inspection I
<B>Undercarriage</B>
Change oil and oil filter while engine is at normal operating temperature.
Use only Castrol TWS Motorsport SAE 10W-60 Synthetic oil, or Castrol Formula RS 10W-60 Synthetic oil, BMW p/n 07 51 0 009 420.
Check transmission for leaks.
Check rear axle for leaks.
Half shafts: Check for leaks at flexible boots.
Visually check fuel tank, lines and connections for leaks.
Check condition, positioning, and mounting of exhaust system. Examine for leaks.
Check power steering system for leaks. Check p/s fluid level; add fluid if necessary.
Check overall thickness of rear disc brake pads using special tool. Record results. If replacement is necessary*:
Examine brake disc surfaces. Clean brake pad contact points in calipers. Grease wheel centering hubs. Check thickness of parking brake linings only when replacing rear pads. Record results.
Remove and install front disc brake pads, check overall thickness.
Check brake and clutch system connections and lines for leaks, damage, and incorrect positioning.
Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage and joint disc.
Check parking brake actuation. Adjust if necessary.
Check all tire pressures (including spare - except M3, M5, Z8 and Alpina). Correct if necessary. Check condition of tires (outer surfaces [left/right]), tread wear and pattern; in case of uneven tread wear readjust wheel alignment if requested.*
Note:If requested rotate all four road wheels as instructed and rebalance.*
Replace M-Mobility System sealant cartridge every 3 years.
Inspect entire body according to terms of rust perforation limited warranty (must be performed at least every two years).
<B>Engine Compartment</B>
Read out diagnostic system.
Check and adjust valves.
Check engine cooling system/heater hose connections for leaks. Check coolant level and antifreeze protection level; add coolant if necessary.
Note: Coolant must be replaced every 4 years (time interval begins from vehicle's production date).
Check level of brake and clutch fluid in reservoir. Add fluid if required.
Replace brake fluid every 2 years (timing interval begins from vehicle's production date).*
Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary.
Check air conditioner operation.
Replace microfilter.
Note: reduce replacement interval in dusty operating conditions.
Reset Service Indicator.
<B>Body/Electrical Equipment</B>
Check battery state-of-charge, and charge if required.*
Check lighting system, i.e., headlights, foglights, parking, back-up, license-plate, interior (including map reading lights), glove box, flashlight, illuminated make-up mirrors, luggage compartment lights.
Check instrument panel and dashboard illumination.
Check all warning/indicator lights, check control.
Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
Check wipers and washer system(s);wiper blades, washer jet positions.
Check condition and function of safety belts.
Recharge or replace batteries for remote controls in all vehicle master keys.
Check central locking/double lock.
Check operation of all latches.
Check heater/air conditioner blower fan, rear window defogger.
Check rear view mirrors.
Visually examine the SRS airbag units for torn covers, obvious damage or attachment of decals, decorations or accessories.
Activate automatic roll-over protection system (if equipped) via diagnostic link.
Note:First remove hardtop/lower top (325Cic and 330Cic only).
<B>Final Inspection</B>
Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission (except M3, M5, and Z8).
there you go
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Oranoco
12
Oct 2, 2015 02:18 PM
stevecfrst1
Sep 30, 2015 05:18 AM
