Had a little go at porting (heads back)
Old Jun 9, 2012 | 04:02 PM
coswurv's Avatar
coswurv
Default Had a little go at porting (heads back)
For our 2 seater mk indy car, im building a nice pinto lump for it so thought id have a go at porting the head myself, its the first one ive done so be kind lol,
think i got a little excited on the inlets so their probably a tad to big but for our build im sure they'll be fine.
Old Jun 9, 2012 | 04:07 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
May I ask what you used?
Old Jun 9, 2012 | 04:12 PM
coswurv's Avatar
coswurv
A blind fold lol
No i used a bosch grinder, with some carbide tips and grind stones.
Old Jun 9, 2012 | 04:15 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Originally Posted by coswurv
A blind fold lol
Doesn't look bad at all mate
Old Jun 16, 2012 | 04:35 PM
coswurv's Avatar
coswurv
bit of an update for anyone who's interested, got the head back from the machine shop who blasted it, fitted the over size valves etc
larger valves
my porting skills
engine pieced together
Old Jun 16, 2012 | 06:05 PM
Vann1992's Avatar
Vann1992
Fair play, at least you had the taters to try it yourself.
Old Jun 16, 2012 | 06:20 PM
COCHYN's Avatar
COCHYN
Fair play for trying it yourself, I wouldn't have the balls to do such a specialist job without any experience. Top marks
Old Jun 16, 2012 | 08:40 PM
st3v3's Avatar
st3v3
it may have paid you to have it flow tested, then if there was a mismatch on any of the ports you could have equalised them a little more.
Looks good though
Old Jun 16, 2012 | 09:39 PM
luke89's Avatar
luke89
Team HOTHOT!
id like to know what sort of power this makes, and spec . dont see much pinto tuning
Old Jun 16, 2012 | 10:11 PM
coswurv's Avatar
coswurv
Looks good though
For what im using it in i dont think it needs to be that perfect, but yes if it was a full blown competition engine i would agree.
Im going to have the engine set up with a guy who's good with carbs, then i may put it on the dyno, i would expect to see 150+ hopefully,
spec is
wiseco 92mm pistons
cossie rods
reground crank
lightend flywheel
whole bottom end balanced
h/p pump
new shells etc
head is ported
large single piece valves
stronger valve springs
kent cam
vernier pulley
fireblade carbs (40mm i think)
couple of pics of the bottom end
Old Jun 16, 2012 | 10:52 PM
Mk4 Lew's Avatar
Mk4 Lew
cracking work mate
moesin2005
Jan 23, 2022 06:28 PM
IAN RS2k
Aug 18, 2015 07:51 PM
ekjim
Aug 17, 2015 08:57 PM
muffster
Aug 17, 2015 08:17 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
