Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Digital vernier calipers....
Old Jun 6, 2012 | 09:54 PM
phil_rs's Avatar
phil_rs
yam yammer
Default Digital vernier calipers....
...talk ta me! I've seen them as little as £10 ranging up to £50+. They won't be used everyday but don't wanna buy some cheap tat. So engineers, what do you think of these?
http://www.ebay.co.uk/itm/3209089541...ht_1224wt_1110
Amazon Amazon
or what else do you recommend?
Old Jun 6, 2012 | 10:03 PM
MONSTER's Avatar
MONSTER
I find the digital verniers to be a bit awkward tbh
Being used to a normal type I find the digital verniers can vary by upto 0.3mm depending on how hard you push the jaws together and it always makes me doubt myself/
If you're not working to tolerances of around 0.2 then I'd stick with a decent set of manual verniers. Mitutoyo are a reasonably priced make
Old Jun 7, 2012 | 06:17 AM
nigel b's Avatar
nigel b
Verniers are fine upto .05 if used properly,anything tighter get a Mic
Mitutoyo are the most common but buck and Hickman are pretty good
Old Jun 7, 2012 | 09:32 AM
phil_rs's Avatar
phil_rs
yam yammer
Thanks for advice lads, it will mainly be used for measuring cam lobes and basic things like that.
Old Jun 7, 2012 | 10:38 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
i have a mac tools one i use alot at work and its never let me down for i use it for in general workshop use!
Old Jun 7, 2012 | 07:37 PM
cabriolet's Avatar
cabriolet
mitutoyo never let me down brilliant feature to convert metric to imperial
Old Jun 7, 2012 | 08:43 PM
st3v3's Avatar
st3v3
The problem with those two verniers is that the wheel mech can play up, even in the short term.
I use my normal type everyday and you soon get a good feel for the clamping of the jaws.
If i doubt myself i calibrate mine againt a 1" slip gauge or a 2" slip just to get the "feel" about right.
What i would say IF you can find a pair with a valid calibration cert then they could be a decent pair.
Old Jun 7, 2012 | 08:48 PM
st3v3's Avatar
st3v3
Heres a few nice pairs-
http://www.ebay.co.uk/itm/Mitutoyo-D...item2a1e5fc59d
http://www.ebay.co.uk/itm/LIMIT-vern...item3f186c1d2a
Old Jun 7, 2012 | 11:16 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
The Laser one on ebay is utter shite. The maintenance Engineer at work has one and it gives a different reading every time on the same thing. I use Mitutoyo ones at home and at work, can't fault them and reasonable price too.
Nov 1, 2015 06:53 PM
mint_s2
Sep 2, 2015 08:58 AM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
