2wd drive shaft/CV issue - pics
My 3dr driveshafts are causing me issues - they don't go back together the way they come apart - am i missing something regading the washers
So any info off anyone that has worked on 3dr shafts before would be great
The washers don't go back on with the circlip this is what i find
With the inner circlip, washer, cv, outer washer - no room for circlip
washer removed - see the ring on the centre joint - not enough space for washer and circlip
Then both washers turned around and built
The with the washer the correct way
Then with both inner and outer washers removed - sitting on the inner clip so the gap you see is to be divided equally for both sides showing not enough space
3dr shafts come with a tapered washer that sits on the inner circlip - so fit up then give the top circlip a tap and it should click in - the other little problem was 2 of the inner ball races were the wrong way around so changed and all is fine. I had to change them so the ball race with the round groove around the centre hole was facing outwards
09-10-2015 07:38 PM
borboyous
22-08-2015 11:17 AM
CabrioTurbo
01-08-2015 11:04 AM
