Mondeo Mk3 wiring diagrams - air con fault finding
Old May 30, 2012 | 05:02 PM
nthorpey's Avatar
nthorpey
Default Mondeo Mk3 wiring diagrams - air con fault finding
Have an issue with the air con compressor on my mk3 tdci, it seems the compressor clutch is not working, not sure on gas pressure and believe if the pressure is too low the compressor disables.
Where is the pressure switch so that i can short it to test compressor ?
Also what is the terminal connections for the compressor clutch so that I can give it 12v and check electrics before i swap the compressor for another.
thanks
Old May 30, 2012 | 05:39 PM
Stu.H's Avatar
Stu.H
thanks
Good luck with all this pal, Ive just sorted my golf out after days of diagnosis.
FYI, the pressure switch on the Golf (could be different on yours) cannot be bypassed, as it sends a duty cycle rather than a ground or voltage which cant be imitated really.
You are best getting it regassed in the 1st instance, then 2nd replace pressure sensor. You could put 12v to the compressor to test it, but if there is no pressure in the system you could end up damaging it and they are the most costly of components.
Kwik fit have a "if it doesnt work after we have regassed, no charge" policy. Maybe worth a shot?
HTH
Old May 30, 2012 | 06:01 PM
nthorpey's Avatar
nthorpey
HTH
ta , got it booked in for the kwikfit anyway on friday, nothing to lose i spose.
Old May 30, 2012 | 07:09 PM
Stu.H's Avatar
Stu.H
Old May 30, 2012 | 07:21 PM
dojj's Avatar
dojj
Resident Wrestling Legend
there is one wire for the compressor and it earths through the body
but trying to test it on the car isn't easy
Old Sep 5, 2018 | 06:27 PM
SimonBUK's Avatar
SimonBUK
Holy thread resurrection !!
Does anybody know what/where this wire is ?
Where does it earth too ?
Old Nov 20, 2018 | 09:03 AM
Check the bog wiring loom hasn't rubbed through on the osf strut tower. My V6 mk3.mondeo air con stopped working and I found a wire in the loom had rubbed through.
DixieTheKid
Jul 23, 2023 10:16 AM
lee2cossies
Aug 26, 2015 10:04 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Ben26
Aug 11, 2015 04:19 PM
marvin
Fiesta RS1800/RS Turbo
Aug 10, 2015 11:14 PM
