Mondeo Mk3 wiring diagrams - air con fault finding
Have an issue with the air con compressor on my mk3 tdci, it seems the compressor clutch is not working, not sure on gas pressure and believe if the pressure is too low the compressor disables.
Where is the pressure switch so that i can short it to test compressor ? Also what is the terminal connections for the compressor clutch so that I can give it 12v and check electrics before i swap the compressor for another. thanks :) |
Originally Posted by nthorpey
(Post 5930915)
Where is the pressure switch so that i can short it to test compressor ? Also what is the terminal connections for the compressor clutch so that I can give it 12v and check electrics before i swap the compressor for another. thanks :) FYI, the pressure switch on the Golf (could be different on yours) cannot be bypassed, as it sends a duty cycle rather than a ground or voltage which cant be imitated really. You are best getting it regassed in the 1st instance, then 2nd replace pressure sensor. You could put 12v to the compressor to test it, but if there is no pressure in the system you could end up damaging it and they are the most costly of components. Kwik fit have a "if it doesnt work after we have regassed, no charge" policy. Maybe worth a shot? HTH :top: |
Originally Posted by Stu.H
(Post 5930943)
Good luck with all this pal, Ive just sorted my golf out after days of diagnosis.
:banana:
there is one wire for the compressor and it earths through the body
but trying to test it on the car isn't easy |
Holy thread resurrection !!
Does anybody know what/where this wire is ? Where does it earth too ? Cheers |
Check the bog wiring loom hasn't rubbed through on the osf strut tower. My V6 mk3.mondeo air con stopped working and I found a wire in the loom had rubbed through.
© 2024 MH Sub I, LLC dba Internet Brands
