Megasquirt EDIS help
Old May 26, 2012 | 09:49 PM
bobster1982's Avatar
bobster1982
Default Megasquirt EDIS help
Hi guys,
Hopefully there are some MS gurus on here
I have a problem with my zetec turbo build. I am using MS2 with an EDIS 4 and I am getting no spark. I have followed the diagram below
I have tried the following things to see if I can resolve it.
Tested 12v supply
Earth is good
Reversed the crank sensor wiring to check polarity is correct.
Changed EDIS for a known good module
Gave module 12v perm live from battery incase I was loosing power on crank.
The only thing extra to the diagram above is a tach signal to my OEM ECU for the dash clocks.
Am I correct in thinking the EDIS will spark regardless if the MS is connected so the problem must be with my wiring?
Please help as I'm at the end of my tether trying to get it going!
Old May 27, 2012 | 10:09 AM
Dlatch!'s Avatar
Dlatch!
can't see the pic for some reason
have you got a laptop connected to the ecu and checked the crank sensor is showing some revs while cranking?
will eliminate one poss cause if you can.
mk3ste
Oct 17, 2021 10:09 AM
Red_bull
Aug 25, 2015 06:27 PM
Ad4m RST
Oct 5, 2006 05:58 PM
xr4x4rs
Sep 13, 2005 08:16 PM
ses
Jun 7, 2005 09:56 PM
