edis 4 modules cvh - zetec FIXED
hello peeps
wondering if anyone can help me
are the edis 4 modules the same between cvh efi mk4 and 1.8 zetec
reason i ask is ican get my zetec running on cvh loom and zetec ecu but badly overfuels
now just wired in the full zetec loom and it wont fire up it sounds as if its firing in wrong order
does this control it?
the pins on the cvh has 12 but only 10 wires
as the zetec is 12 pins and has 12 wires
im using cvh edis at the minute as i dont have the zetec one at hand
As far as I know (99% sure), electrically, all EDIS 4 cylinder modules are the same.
The firing order IS controlled by the module.
Here is tech website with pin out info and how it works .......
http://www.dainst.com/info/edis/edis.html
thats some good information there thanks
but thats how it is at the minute
ive got fuel, spark but it wont fire up
im running a cvh flywheel if that makes any odds but by that explanation it doesnt
its says it works off cam sensor aswell so maybe my cam sensor isnt working
i have no idea how this stuff works ive just followed the wiring diagram from haynes for a zetec using xr2i engine loom which is the same according to the manual as ive traced every wire in it today and it matches
i just dont know anymore
The cam sensor is ONLY used for fuelling and the car will probally run without it
and MAY overfuel but NOT badly.
One thing to check is that you have the crank sensor wired the correct polarity as
this could seriously put the ignition timing out.
i havnt checked
i thought it didnt matter which way round the wires went lol
as i had to lenghten them
also it says it needs a 36-1 flywheel
now i have a cvh flywheel on my lap and can only count 35 rings ?
how can i work this out
arh thats ok then so zetec must be the same
as they use edis 4 as well
ill go and check the crank wiring again and hope its that then
if not then im lost
thanks very much
top bloke
if not then im lost
thanks very much
top bloke
fixed
ive been on this twoi days working wiring out
thankyou simon for the information
in the end it was the crank wires the wrong way round
but fires up first turn and runs sweet
thanksyou for the advice much appriciated
mk3ste
17-10-2021 11:09 AM
07-10-2015 01:56 PM
