Is it true
Old May 24, 2012 | 08:59 PM
rsturbo27's Avatar
rsturbo27
Default Is it true
That after a head gasket failure you have to reskim the head?
Old May 24, 2012 | 09:05 PM
7sean7m7's Avatar
7sean7m7
It's advised..
Old May 24, 2012 | 09:11 PM
tommytwotanks's Avatar
tommytwotanks
you dont have to skim the head, but always check with something like a metal ruler (on end) to make sure it is flat, make sure you get all the old gasket off first as this will give you a false reading if you dont, i dont know what they charge now, and they normally like them stripped down,
Old May 24, 2012 | 09:12 PM
Shings's Avatar
Shings
BUT
Not always necessary.
For example....
If you spotted an over heat and turned off immediately and through whatever means found that the head gasket had gone AND your head gasket is a fibre type you're likely to be fine.
BUT
If it's metal prob best to skim
AND
If you drive it and fuck it up and over heat it over and over again it's best to skim
Old May 24, 2012 | 09:42 PM
rsturbo27's Avatar
rsturbo27
Ok thanks might get it skimmed and try fitting myself gotta learn sum way
Old May 24, 2012 | 10:08 PM
martysmartie's Avatar
martysmartie
As a general rule, yes.
Especially if it has overheated, as the head would have warped.
What are you like with mechanics?
You will need a torque wrench, along with various other tools and you need to know the tightening sequence etc, if you get this wrong not only will it need to be redone all again but you could end up damaging something.
Martin
Old May 25, 2012 | 07:35 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
it really is false economy not to have it skimmed, because you run the risk of forking out for another gasket set if it fails straight away. do it right, do it once
Old May 25, 2012 | 07:37 PM
Jay,'s Avatar
Jay,
Sponsor
always best to get the head checked
Old May 25, 2012 | 07:48 PM
gaz-hull's Avatar
gaz-hull
I would get it done mate when my went i got it done and the cost was nothing compered to other parts and it puts your mind at rest!as has been said do it ince and do it right
Old May 25, 2012 | 08:52 PM
stevieturbo's Avatar
stevieturbo
C**t
You would need to have a very good reason to not have it skimmed.
Old May 25, 2012 | 09:04 PM
Oranoco's Avatar
Oranoco
I always have the head checked by my local guy. He has on a few occasions phoned to say the head is fine and no skimming required. He also phoned me on a Fiat head to say there was nothing left to skim to as so much meat had been removed in the past, a worry on a 40k mile car
Only time skipped the check was when my Felpro failed but that went between 2 cylinders and left no marks on anything other than the crap gasket
Old May 25, 2012 | 09:37 PM
rsturbo27's Avatar
rsturbo27
Any1 know rough price on skimming a head it's a stage 4 head I was told when I bought car
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
May 31, 2016 09:28 PM
Oct 9, 2015 07:38 PM
landaqmabba
Sep 15, 2015 07:16 PM
yorkie92
Sep 6, 2015 05:34 PM
