Rear wishbone
Old May 23, 2012 | 01:39 PM
simonmcf's Avatar
simonmcf
Default Rear wishbone
Hi guys,
quick questions.
I know there is a slight variation on the rear Mk4 wishbones as some had load valves and some did not.
However,does the size of the rear inner wishbone vary?
I ordered poly bushes but they are way too big!
Thanks
Simon
Old May 23, 2012 | 02:31 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
If you could be more specific it'd help, are your bushes the floflex ones?
I assume you mean the bottom arm which bolts to the hub. When i poly bushed mine i had to drill/burn out the inner bushes and press the new ones in, they're moulded in originally so aren't easy to get out.
There's another variation of wishbone too, the turbo's had an extra bracket for attaching the roll bar too, but the rest of the mountings should still be the same.
Might have a picture or two of mine when i painted and re bushed them a few months ago if you need to see how they were.
Old May 23, 2012 | 02:39 PM
simonmcf's Avatar
simonmcf
No not the hub one, thats the outer, the inner is the one which sits under the chasis if you get me.
No its not floflex. I got them off a rally specialist.
The differnce in the RS to the others is the rear load valve thing.
Its the actual size of the bush Im talking about
Robbed pic of Daz, left bush is just beside the orange exhaust carrier, the right inner bush is obvisouly opposite the left
cheers for reply
Old May 24, 2012 | 12:19 AM
AstoN_B's Avatar
AstoN_B
Yeah i know which you meant, i was referring to the hub due to a brain fart. But its the one which joins the hub to the inner chassis part.
Thats the part i was on about. As far as I'm aware the bushes aren't easily replaceable like they are on the front, i bent on of my rear arms slightly trying to get the bushes pressed to so had to straighten it again and drill/burn the rubber out. I'll see if i've got a decent picture of just the arm with the poly bushes in.
Old May 24, 2012 | 12:31 AM
AstoN_B's Avatar
AstoN_B
Hopefully these can be of help:
Stripped for paint and original bushes removed
During enamel coating
Size:  41.8 KBName:  6bb952cc.jpg
After coating and bushes fitted
I found that the original bushes were bonded rubber to a metal outer which was pressed into the arm, possibly with the arm heated to allow a tighter fit. With all that removed leaving just the arm itself the bushes i got from Floflex were a tight but good fit, required ever so slight filing of the inner edge to get them to press in square without catching and twisting, and a wipe of copper grease helped too.
They do look quite chunky and fit very snugly into the inner mounting points on the car.
Old May 24, 2012 | 12:41 AM
AstoN_B's Avatar
AstoN_B
They were stiff too, i fitted the Spax adjustable full kit when i was building it back up not realising it was more suited to track work. Bit annoying when you weren't in the mood for a firm ride, but fantastic the rest of the time.
Turned it from rolly, sloppy 22 year old drive to a balanced, keen and controllable toy. I did the steering rack bushes in poly too which i wasn't sure about at first, but it made such a difference. I could feel a bit of movement at the tyres even though the wheel wasn't moving beforehand whilst cornering over a crest for example, afterwards it was totally predictable and direct.
Old May 24, 2012 | 07:49 AM
simonmcf's Avatar
simonmcf
cheers man, I have the bushes out already.
would you mind taken some measurements of the diameter of the bush.
The inside of my arm (where the bush is meant to sit) is 4cm by 4.5cm
Old May 24, 2012 | 09:53 AM
AstoN_B's Avatar
AstoN_B
Im afraid i can't mate i haven't got the car anymore, sold it a few months ago!
My bushes came in two halves with a steel tube through the centre, which i assume was so the bushes were snug in their mounting and the tube stopped the chassis crushing them to the point where they stopped the arm moving.
Where the bush was, is there still a metal lip/hoop inside? If you don't get that out i think you'll struggle getting new ones in. It was easier to get the rubber to tear away from its metal outer than it was to get that out of the arm. Might be a simple case of a few mins with a hacksaw blade if the ring is still in yours?
Old May 27, 2012 | 03:40 PM
simonmcf's Avatar
simonmcf
Got it sorted today - I still had the orginal metal ring in it- cheers
Old May 29, 2012 | 08:07 PM
AstoN_B's Avatar
AstoN_B
Good man.
Old Jun 18, 2012 | 07:19 PM
Patto's Avatar
Patto
i got a front and rear set from flo flex and there is no chance the outer rear wishbone buhes they sent me will fit they are to wide, anybody had this problem with them...???
Old Jun 18, 2012 | 09:17 PM
simonmcf's Avatar
simonmcf
Have you taken out the metal sleeves? I thought the same but just had not taken out the sleaves
Old Jun 19, 2012 | 06:57 AM
Patto's Avatar
Patto
i didn see any metel sleeves in any of the 4 holes but ill have a check
Old Jun 19, 2012 | 07:58 AM
simonmcf's Avatar
simonmcf
you would have had to cut them out.
Habe you taken the old bushes out yet?
Old Jun 19, 2012 | 06:03 PM
Patto's Avatar
Patto
hiya matie, i am talking about the outer bushes the ones that are top hat shaped there is 2 a side, i have the old ones out and there is no metal sleeve on the bushes although the inner ones that bolt to the chassis have metal sleeves, as for the outer ones there is no way they will go in they measure around 28mm and the ones i took out are about 22mm.
Old Jun 19, 2012 | 09:43 PM
simonmcf's Avatar
simonmcf
Sorry cant help cos mine had powerflex in already
Old Jun 19, 2012 | 10:15 PM
Patto's Avatar
Patto
ok no worries
Old Jun 20, 2012 | 12:45 PM
AstoN_B's Avatar
AstoN_B
Have you had a good look at my pictures above? The last one shows the rear arms with newly fitted flo flex bushes.
Just make sure there isnt an extra metal ring inside where the new bush should go, I had to bevel the ends of some of the bushes to get them to go in straight, and a bit of copper grease made them easier to squeeze in with the vice.
Old Jun 20, 2012 | 01:10 PM
Patto's Avatar
Patto
CheeRS Aston, but there is deffo no sleeve on the outer bushes, i rang flo flex again today and they said there is a 22mm bush listed for there aswell as some taking the 28mm so not sure really but there sending me the correct ones
Old Oct 5, 2012 | 10:05 AM
marc_gti's Avatar
marc_gti
bump this back up
im after some knowledge and confirmation on something, i removed the rubber bush a while ago, now ive tried to re-fit the new bushes and they are very tight and seem to big - ive noticed above that the old bushes have a metal sleeve is this correct?
and if so do both the inner and outer bushes have metal sleeves?
and whats the best way to remove them?
thanks
Old Oct 5, 2012 | 10:16 AM
simonmcf's Avatar
simonmcf
use a small hack saw - take off the blade, put it into the sleeve, then reattach blade, cut and pull out with pliers
Old Oct 5, 2012 | 04:00 PM
marc_gti's Avatar
marc_gti
did you remove the sleave for the outer wishbone ones?
Old Oct 5, 2012 | 08:46 PM
RSmark84's Avatar
RSmark84
head over to the RSOC and look for the rear tie bar thread in the S2 section.... plenty of info and pics about these bushes and wishbones as ive just been shot in the foot by fooking flo-flex crappy bushes. Powerflex all the way...... turns out Flo-flex actually sell smaller bushes that you need but funnily enough me and someone else bought the same kit and both were the wrong ones. Flo-flex have fooked up their end and wont admit it.
DO NOT buy Flo-flex as per the thread posted in the RSOC S2 section.
Old Oct 6, 2012 | 01:38 AM
simonmcf's Avatar
simonmcf
Agree with mark , but u need to take sleeve out with hack saw simple as
Old Oct 6, 2012 | 01:41 AM
simonmcf's Avatar
simonmcf
Sorry only replaced inner not outer
Old Oct 6, 2012 | 06:11 AM
marc_gti's Avatar
marc_gti
ive taken both inner and outer sleeves out. so what your saying is ive now fucked my wishbones?
Old Oct 6, 2012 | 09:16 AM
simonmcf's Avatar
simonmcf
Was jarrd last night - if u have taken the bush out then cut out the sleeve then just push in new bush, it may need limitless shaving- done!
Old Oct 6, 2012 | 07:25 PM
marc_gti's Avatar
marc_gti
all three sleeves? i was worried about the two outer ones which i have removed
just seems strange that some people leave the sleeve in and others remove them, will it handle the same with them removed?
Old Oct 6, 2012 | 08:20 PM
RSmark84's Avatar
RSmark84
If you remove the sleeves and put the rear end on axle stands with the wheels on rock the wheels left to right if they move it'll fail an MoT and means theres play in the bushes....this happened with the flo-flex outer bushes fitted and sleeves fitted so without them it'll be even worse.
Old Oct 6, 2012 | 08:22 PM
marc_gti's Avatar
marc_gti
Can you buy these poly bushes with the sleeves?
Old Oct 6, 2012 | 09:07 PM
RSmark84's Avatar
RSmark84
yeah see RSOC thread as i mentioned above.
155lee
Sep 6, 2016 11:10 AM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
The Enigma
Sep 12, 2015 10:12 PM
cossirob
Sep 3, 2015 09:17 PM
