Do RS Focus wheels fit on ST220 ?
I now have a ST220 estate, 18" alloys ET52.5, I would like to fit mk2 RS Focus 19" alloys.
Are they the right offset and fit ?
Sure I,ve seen a ST220 on here with them fitted
I used the hubcentric spacers on mine, think they were 15mm. The spacers themselves bolt to the hub, then the wheel bolts to the spacer. That way it helps keep everything square and secure.
I'm near Swindon, if you're ever up this way your more than welcome to try my wheels on to see if they clear ok!
Thanks for the offer of trying yours
Kev
The missis sister has them fitted to her ST TDCi the front ones go straight on the rears need a 10mm spacer and longer studs to clear the rear shock absorber.
Rich
Rich
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
blakey100
Aug 4, 2015 08:17 PM
