Ignition advance probs/ how to find out level car tuned too?
Old 06-05-2012, 10:28 AM
simon521
simon521's Avatar
Default Ignition advance probs/ how to find out level car tuned too?
Hi
Can anyone assist me. I bought a project in bits 3 yrs ago just put it on rollers last week and the ignition timing is not advancing as you go up the revs.
I know the ecu controls this but what tells the ecu?
As I said I'm new to he car and do not know what it can do how do I identify the ecu chip? What it is programmed to do? And what level injectors are fitted.
Has db10 cams, light blue injectors, vernier pulleys.
Any help would be greatly appreciated.
Old 07-05-2012, 08:37 PM
opposite lock
opposite lock's Avatar
Going by the brief spec you,ve rebuilt a cossie.
To find the chip identity take the ecu apart .Some ECU,s are written on but personally i,d still check the chip itself.If an author of the chip is available they should be able to provide the chips exact spec and make sure it is for your engine spec.
JoeyBoyden
04-01-2024 02:36 PM
big_Rad
15-09-2017 09:36 AM
marvin
Fiesta RS1800/RS Turbo
10-08-2015 11:14 PM
tommylommykins
Ford Fiesta
08-08-2015 08:01 PM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: Ignition advance probs/ how to find out level car tuned too?
