Escort RS Turbo massive running problem please read!....totally stuck
A Webb
i have a Escort RS Turbo series 2 and wont run when you start it, it chucks out black smoke then stalls and is massivley over fueling
then if i unplug the plug at the rear of the metering unit with the black unit on (fuel pressure acuator) it runs absolutley fine
i have tried 2 other metering units and changed the wiring loom and its still the same!
im totally stuck and havn't a clue whats going on and what to do next?
i would carry on running with it unplugged but i know it gives you extra fuel when boost comes on so i don't want to run it lean so please what do i try next people??
kosienutter
31
22-08-2015 09:55 AM
