my rs is pissing me off in the mornings when cold
Old Apr 29, 2012 | 03:23 PM
fiesta wrs's Avatar
fiesta wrs
Default my rs is pissing me off in the mornings when cold
i love the car to bits but whenever i use it for the 1st time that day it drives like a bag of dog turd.
i have a scangauge fitted and whenever it plays up it turns the scangauge off, and once back to normal it comes back on ??
it misfires through every gear and judders about as if its running on 2/3 cylinders. once warmed up and back to normal its fine
im running tubular manifold,
mongoose exhaust,
tuna remap
msd coilpack
k&n gen2 filter
running 22 psi
just for those who may wonder if it could be any of the mods.
also at around 10 psi theres a slight judder
any advice would be great
Old May 2, 2012 | 12:20 PM
Sticky.'s Avatar
Sticky.
Is the tank below a quarter?
Old May 2, 2012 | 12:53 PM
Fezman1's Avatar
Fezman1
Donno about his but mine does it with tank below a quarter...
whats the problem/solution????
Old May 2, 2012 | 06:33 PM
Sticky.'s Avatar
Sticky.
Keep it above a quarter
Mine does the same but starts perfect with half a tank in.
Old May 2, 2012 | 06:45 PM
kieran265's Avatar
kieran265
mine has started misfiring frm cold but only lasts 30 seconds or so. surley having under quater of a tank wouldnt cause this? mayb related to your issues
Old May 2, 2012 | 06:56 PM
Mark_'s Avatar
Mark_
if it does it when below 1/4 wouldnt that point to dodgey fuel pump?
Old May 3, 2012 | 09:35 PM
R5 5KOT's Avatar
R5 5KOT
That's what I was thinking to mate
Old May 12, 2012 | 11:34 PM
IanC's Avatar
IanC
dose it only do it untill its up to temp? mine dose it too nothing to worry about it its nothing just dont boot it till its warm!
Old May 14, 2012 | 05:28 PM
Sticky.'s Avatar
Sticky.
Ian, we're about are you in St Helen's?
Old May 16, 2012 | 06:15 PM
simonRSfocus's Avatar
simonRSfocus
what base map are you on AF or AE as AE was always a pain for cold starts thats why AF was introduced but that can cause a cough at 4500rpm when tuning what are your plug gaps set at?and are they in good condition?
Old May 17, 2012 | 10:29 PM
Sticky.'s Avatar
Sticky.
Dumb question...
What is AF & AE?
Old May 17, 2012 | 11:27 PM
IanC's Avatar
IanC
Different versions of the ford maps mate af is the revised map easy fix to this tho is let your car warm up before u spank it it's just over fueling cus of cold start
Old May 18, 2012 | 10:38 AM
Sticky.'s Avatar
Sticky.
Think the car will be coming to you Ian
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
A.t.p
Oct 23, 2015 07:54 PM
dojj
Sep 29, 2015 10:32 PM
