ofam and 21psi??
Old Apr 24, 2012 | 09:36 PM
wedge07's Avatar
wedge07
Default ofam and 21psi??
going to be putting my new ofam ecu in car when i get lambda n AFR. i read somewhere the standard fiesta rst engine will do 21psi at stock??
if this is true i want to run this in my fiesta rst engine with steel rods and forged pistons at 21psi.
i want to try and achieve around 250 bhp and around 230 lb ft.
i had mine rr'd at 14psi 205.7bhp and 186.9 lb ft which is pretty good i suppose but i want that little bit extra.
what is needed to achieve this? i dont want to go 1.8 or 2.1 bottom end just 1.6 will do. and help will be great thanks
Old Apr 25, 2012 | 07:12 AM
Rogeyboy's Avatar
Rogeyboy
Whats your spec?
You can run as much boost as you like as long as your injectors can fuel for it... Standard CVH rods give up around 230bhp i think. So if you are using steels you'll be ok for 250 and alot more!
Old Apr 25, 2012 | 09:55 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah as Roger says forged rods and pistons are good for 350bhp+ so you can run whatever you like providing you have enough fuel.
For 250bhp and similar torque all thats needed is a stage 3 T3 (.48/55) and a FMIC.
Old Apr 25, 2012 | 10:22 AM
Rob_DOHC's Avatar
Rob_DOHC
Hi dude, technically the ecu is up to the job.. If you want to run more boost a 4bar map sensor will be required.
I personally would recommend steel rods and forged pistons... or at the VERY least some ARP con rod bolts... with standard rods you really need to keep the rev limit around 6k IMO.... I use standard pistons and steel rods.
Rob,
Old Apr 25, 2012 | 12:07 PM
Rogeyboy's Avatar
Rogeyboy
For my next build im going to use steel rods... Altho i'll be happy to make a genuine 220bhp with a rev limit of 6/6500rpm. For now i'm loving the car on 1bar of boost, circa 170-180bhp i hope!
Old Apr 25, 2012 | 12:16 PM
mgtkr1's Avatar
mgtkr1
just to add, what is the maximum boost you can safelt run on a t2 and a t3?
Old Apr 25, 2012 | 12:25 PM
Rob_DOHC's Avatar
Rob_DOHC
Boost is a very general term tbh mate... at the end of the day turbo spec will dictate how much boost you run....
But I have run over 20psi on a stage 2 T3 for some time, and it hasn't poo'd its turbine down the exhaust yet
Old Apr 25, 2012 | 12:27 PM
Rob_DOHC's Avatar
Rob_DOHC
It'll be worth it just need to get you some nice juicy injectors and you'll piss 220bhp with your turbo Roger.
Old Apr 25, 2012 | 03:05 PM
wedge07's Avatar
wedge07
My spec is 1600, steel rods, forged pistons, lightened and balanced bottom end, lsd box, beiges, bayjoo, full front mount, t3 hybrid stage 3 ( i was told when bought), mfi fuel pump, where can i get a a 4 bar map sensor as mine is 3 bar map.
Old Apr 25, 2012 | 03:58 PM
Rogeyboy's Avatar
Rogeyboy
Yet another 200+ bhp on Beiges Alot of people have seen this power, but the calculations say its not possible...
Rob - my next move is 440cc (astra vxr) injectors, once the clutch is sorted!
Old Apr 25, 2012 | 04:23 PM
wedge07's Avatar
wedge07
The lad i bought engine off said he was running 21psi at had it running 232 bhp on beiges. How are vxr injectors, wat could u get 250bhp out of them and do the fit direct replacememt or do i need fuel rail?
Old Apr 25, 2012 | 04:58 PM
luke19790_3's Avatar
luke19790_3
upgrade your injectors first.
232 bhp on beiges
Old Apr 25, 2012 | 05:12 PM
Rob_DOHC's Avatar
Rob_DOHC
Sadly 230bhp on beiges won't happen. Personally I would highly recommend siemens deka, vxr injectors are okay to around 240bhp on a cvh due to the poor BSFC.
As for the 4bar map sensor, they are supplied as an optional extra with the OFAM, you can get it as an upgrade too.
Your engine spec seems good, and capable of good power. Who is tuning this for you? I would have a chat with them when they start mapping, they can gradually (and safely) increase the boost whilst making sure there is no det.
What kind of boost control do you have?
Rob,
Old Apr 25, 2012 | 05:13 PM
Rob_DOHC's Avatar
Rob_DOHC
Ultimately, with your engine turbo spec and injector size will dictate power to a certain extent.
Over 200 is very easily achievable with the correct turbo and injectors. A proper stage 3 turbo and siemens dekas should be good for high 200's like 280 comfortably.
Rob,
Old Apr 25, 2012 | 05:28 PM
wedge07's Avatar
wedge07
What turbo do i upgrade to and where can i get some injectors to get me that high? I use mikeanics in congleton, but not sure if he will touch ofam?? I need learn it myself really
Old Apr 25, 2012 | 09:27 PM
studabear's Avatar
studabear
wedge07 i can give you a contact whos mapped mine, he's down your way too i think
Old Apr 25, 2012 | 09:55 PM
wedge07's Avatar
wedge07
Really?? that would be mint if u can, where r they based mate?
Old Apr 25, 2012 | 09:59 PM
studabear's Avatar
studabear
pm on its way
bigryrs
Sep 7, 2015 06:45 PM
Cameron
14
Aug 9, 2015 06:28 AM
carl-0170
Fiesta RS1800/RS Turbo
Jan 25, 2014 08:45 AM
Oppliger Motorsport
Nov 2, 2013 11:46 AM
jan247uk
Jun 19, 2012 10:25 PM
