Stalling engine help
Old Apr 22, 2012 | 06:50 AM
The Glass Man's Avatar
The Glass Man
Default Stalling engine help
Hi fellas,
Just rebuilt my cvh, now started it up yesterday and she runs for about 5 second then stalls, and if i try to rev it stalls too. It will only start with the MAF off
I'm sure i have all hoses in correct places and i havint played with the fuel pump, filter or lines.
Cound anyone point me in the right direction?
Ta
Old Apr 22, 2012 | 07:39 AM
The Glass Man
Just been and had another look and all hoses and wiring seems to be in the correct place.
Problem was, would only start with maf sensor off and would stall when revved.
Ta for any help
Old Apr 22, 2012 | 08:10 AM
The Glass Man
Please help Passion ford, i'm sitting not knowin what to try next.
I'm wondering if the very small amount of petrol that was in the tank 6 weeks ago could of evaporated, as the head was off and the petrol lines to the engine was off too.
Maybe just clutching at straws...
Ta fellas.
Old Apr 22, 2012 | 08:14 AM
studabear's Avatar
studabear
put a gallon in then.
Old Apr 22, 2012 | 08:17 AM
The Glass Man
I'm a 2 hour walk to a garage at the minute, well until 12 when my transit comes back.
I will as soon as i can though,
Old Apr 22, 2012 | 08:22 AM
vaughant's Avatar
vaughant
Yeah,try some fresh fuel,I always find it helps but it certainly sounds fuel/airleak related as if it were ignition I'd say it wouldn't even fire.
Sorry I can't be of much more help but it sounds like your on the right path.
Conversely,have you checked that the fuel cut off switch hasn't been inadvertently activated?
It's on the passenger kick plate from memory.
I'm sure you can test for fuel pressure on the injector line via the little tyre style valve,be aware it may squirt out under a fair bit of pressure so take care with your eyes.
Old Apr 22, 2012 | 02:19 PM
The Glass Man
Update,
New petrol in tank, but the broblem is is cannot hear the pump pruiming when i turn ignition to posistion 2.
I'm sure iv check the correct relay, r2 and that is fine.
So what else could i check, wires to pump and pump its self?
How to test the pump and where is it?
Ta!
The Enigma
13
Aug 20, 2015 09:38 PM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
