CVH Specs....
Old Apr 19, 2012 | 03:26 PM
TIL13R's Avatar
TIL13R
Default CVH Specs....
Hello all,
I am looking rebuild my EFI Block but wanting to know what specs everybody runs to achive 250bhp....
I have a st3 T3 from TT, stg 3 port and polished head, will be fitted with newman cam and solid lifters, management and injectors are to follow.
Basically i want a well built bottom end that can handle the power.
So what piston and rod combo's would you guy reconmend...?
Tiller
Old Apr 19, 2012 | 03:46 PM
darrenb16two's Avatar
darrenb16two
Ive got wossner pistons & pec rods, theyve coped with 24psi with no problems. What management etc you running?
Old Apr 19, 2012 | 04:05 PM
TIL13R's Avatar
TIL13R
thats the piston and rod combo i been looking at... What power and spec is your CVH... management i was looking at Omex 600 but am open to ideas...
Tiller
Old Apr 19, 2012 | 04:14 PM
darrenb16two
Yeah very good piston & rod combo for the money, you wont be disapointed. Not sure on the power my car makes as it was live mapped and not rolling road mapped, will put it on the rollers at some point though. As for management i would say go for what ever your tuner is best working with, i would stay clear of the cheap shit though mate
Old Apr 19, 2012 | 04:23 PM
TIL13R's Avatar
TIL13R
Where did you purchase your piston and rods from...?
Thats another thing i am unsure on what tuner to use/set up the car...
Old Apr 19, 2012 | 04:34 PM
darrenb16two
I brought my pistons & rods from jano @ oddkiddcreations, pretty sure im right in saying he sells them cheaper than anywhere. Theres sadly not to many good tuners around these days mate, lots of bullshit and wankers just after your money. Only one place for me!
Old Apr 19, 2012 | 06:46 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Stock pistons are good for 300bhp and the rods around 240/250bhp if you keep the limiter as stock and don't spend your time bouncing off it.
If not then PEC and Wossner are the best value for money IMO, I ran circa 280bhp @ 32psi.
But do not go low comp!! It's a waste of time unless you want over 300bhp and will just cost you response!
The rest of your spec is spot on for 250bhp+ with good mapping.
Old Apr 20, 2012 | 07:15 AM
Rogeyboy's Avatar
Rogeyboy
Management i recommend OFAM...
Its good to know a standard ish engine will cope with circa 230bhp, as thats what i want... I'll knock the limiter down abit 6,300rpm as the cvh has such a massive hit of torque you don't need to rev the tits off it.
Karlos what boost level did you max your 440cc injectors out at?
Old Apr 20, 2012 | 09:10 AM
TIL13R's Avatar
TIL13R
Well it seems like the pistons and rods are going to be Woosner & Pec.. What other key things would you reccomend when rebuilding the car... Oil pump water pump etc... I was thinking genuine ford for these bits... Unsure on headgasket and bolts..
Any Ideas and tips...?
Tiller
Old Apr 20, 2012 | 09:42 AM
matthart's Avatar
matthart
I put a brand new genuine pump on mine when it was rebuilt, but even with the guy at Ford giving me sympathy discount, I think it cost more than the wossner pistons!
As I'm sure everyone is about to say, standard (Payen branded I think) RST headgasket and normal stretch bolts.
Old Apr 20, 2012 | 09:48 AM
Danster76's Avatar
Danster76
Ive got wossner pistons and pec rods in mine, newmans cam etc with siemens 55's running link mgt mapped by mark shead. Solid and reliable.
Old Apr 20, 2012 | 02:53 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It's not at what boost they maxed out at Rog, as boost is relative to the engines VE (it's ability to breathe), it's what power they maxed out at, which was 220bhp...
What I mean by the above is my engine might of flowed enough air for 230bhp @ 19psi but yours may only flow for 200bhp at the same pressure if you see what I mean?
Oh and they were 480cc injectors mate.
Tiller
Genuine oil and water pump if money allows and as above a genuine Ford HG and stretch bolts or Payen (which is who make the Ford one), proven for over 350bhp.
Old Apr 20, 2012 | 03:03 PM
Rogeyboy's Avatar
Rogeyboy
Oh ic... And was it 19psi that you saw 230bhp with? Im hoping mine should be at least 200bhp @ 18-20psi on the 440cc's with the 48/55 t3 on it.
What can be done to improve the engines VE, headwork and a bigger turbo?
Old Apr 20, 2012 | 03:21 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes it was but that was on a .36/50...
To improve an engines VE as you have mentioned, headwork, cam, turbo, TB, inlet and exhaust manifolds, anything that has an effect on the way the engine takes in fresh air and then exhuasts it.
Your .48/55 will flow more at any given boost pressure than my .36/50 (it's actually the exhuast housing that changes the VE significantly in this instance), but... if for example you have a stock head then this will reduce your VE (making it harder to push the air through and raising the back pressure AKA boost pressure!) when compared to my NMS/Newman Ł1000 head.
Old Apr 20, 2012 | 03:41 PM
TIL13R's Avatar
TIL13R
Ok so seems i best get onto my local ford dealer then to source a few parts, With regards the headbolts standard or arp's...??
Old Apr 20, 2012 | 03:55 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
good to know karlos,
im getting 261 @ 10 psi with a morspeed race head newman cam, ported s1 inlet, 4x4 ported compressor housing t3 turbo
Old Apr 20, 2012 | 04:10 PM
darrenb16two
Yeah definatley get yourself down to ford for headgasket, head bolts and oil pump. Get yourself some arp con rod bolts to go with your wossner pistons an pec rods and you've got yourself a sorted engine that will take all the power you can chuck at it. As long as a total spanner isn't building it of corse lol
Old Apr 20, 2012 | 04:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Stock stretch bolts (Ford or any motor factors) not ARP's mate, again proven for over 350bhp.
That's an amazing VE to produce such big BHP at such low boost!!!
Old Apr 20, 2012 | 04:56 PM
TIL13R's Avatar
TIL13R
Cheers for all the tips lads... im sure more questions will follow lol...
I rebuilt my old N/A cvh to 130bhp just with double the power wanted to make sure i buy the correct stuff so it dont fail on me...
Cheers again
Tiller
Old Apr 20, 2012 | 07:39 PM
Canada1's Avatar
Canada1
Is that with a 1600cc engine? What rpm peak power?
Old Apr 20, 2012 | 10:38 PM
G2RSR's Avatar
G2RSR
Bodybuilding
its a 2.0 peaks at 7k
Old Apr 23, 2012 | 07:54 AM
TIL13R's Avatar
TIL13R
I have now got pricing for new gaskets and water pump but looks like the oil pump is on ford back order....
So had a look on burton power, has anyone used either of these pumps...?
http://www.burtonpower.com/parts-by-...h/cv401hp.html
or
http://www.burtonpower.com/parts-by-...cvh/cv401.html
Tiller
Old Apr 23, 2012 | 11:43 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Wait for a genuine Ford pump and fit a high pressure spring.
Old Apr 23, 2012 | 01:48 PM
Karlos G's Avatar
Karlos G
Balls Deep!
or
Tiller
I have ran a Burton HP pump without issue.. But others say they have failed easily so could be a risk.
Old Apr 23, 2012 | 02:30 PM
darrenb16two
Definatley wait for a genuine one an fit a high pressure spring mate
Old Apr 23, 2012 | 02:51 PM
TIL13R's Avatar
TIL13R
Well looks like im going to have a hunt on my hands...
Whats this high pressure spring you guys are talking about...?
Tiller
Old Apr 23, 2012 | 05:08 PM
Karlos G's Avatar
Karlos G
Balls Deep!
No need for a new relief valve spring, just shim/pack the one thats already there if you want higher oil pressure.
Old Apr 23, 2012 | 06:48 PM
Danster76's Avatar
Danster76
For reference, if you have a S1 crank (as I do) you need to use an S1 oil pump which is no longer available from ford so an after market pump is the only option IME. Pleased to be corrected if this is wrong?
Old Apr 25, 2012 | 02:06 PM
TIL13R's Avatar
TIL13R
bit of an update on the the oil pump situation... Ł232.88 but its on back order from ford....
Arrrggggggg.....
Old Apr 25, 2012 | 04:14 PM
russ rs's Avatar
russ rs
That's Stupid price how they come up with that
Old Apr 25, 2012 | 05:22 PM
TIL13R's Avatar
TIL13R
No idea... I looked at my old paperwork and say 3 years ago i brought one for Ł110...
Old Apr 27, 2012 | 12:13 PM
TIL13R's Avatar
TIL13R
*UPDATE*
I have found a oil pump 6169335 for Ł180 genuine ford but been told its for Escort RS Turbo but my engine is Fiesta RS Turbo... im 95% sure its the same pump but i have this doubt in back of my mind...
Can anybody confirm if its the same Oil Pump...?
Tiller
Old Apr 29, 2012 | 11:00 PM
Marc D's Avatar
Marc D
yer will be the same oil pump mate. only different oil pumps are to 86 and from 86 same with water pumps and timing belt tensioners
Old May 9, 2012 | 10:06 PM
TIL13R's Avatar
TIL13R
UPDATE...
Finally found one... GS Motorsport had one on the shelf...!!!
My next question is Newman cam and solid lifters... has anyone ever fitted these before...? If so any tips or hints...?
Tiller
Old May 10, 2012 | 11:10 AM
Karlos G's Avatar
Karlos G
Balls Deep!
https://passionford.com/forum/ford-e...-few-tips.html
Old May 10, 2012 | 11:39 AM
darrenb16two
As karlos link says above really! Fucking boring and fiddly job tho lol
Old May 10, 2012 | 11:44 AM
Rogeyboy's Avatar
Rogeyboy
Good read that link...
mk3ste
Oct 17, 2021 10:09 AM
sridgett
13
Sep 27, 2015 06:03 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
Russp
Escort Range
Sep 18, 2015 07:39 PM
