Fitting cams to a puma 1.7
First of all i was wondering what cams to go for as there is a few different makes out there kent, piper etc... I will be using the car on the road so nothing to serious. Also when i buy the kit what else should i get like new gaskets etc anything that will need changed when i am fitting them. And if anyone has a link to a guide or can tell me anthing else important it would be much apricated.
I have 4-2-1 mani, decat and miltek exhaust as soon as the cams are fitted its geting mapped. Whats this hd bottom end bolts your on about? And would i need a new rocker cover gasket etc?
cheers mate i just found the piper cams on the oc motorsport website at Ł440. Would i be better going to get a custom map on a rolling road or buy one of those programs of the internet for the ecu there both about the same price...
HD bottom end bolts allow you to safely raise the rev limit over standard, needed with decent cams. Also saying 'piper are the best' is a very broad and pointless statement, due to them making different spec cams. Shawspeed cams are made by piper though, to shawspeeds spec. Also avoid Pumabuild, they're cowboys!
What sort of power are you looking for firstly?
After using Pumabuild a lot and having experience of shawspeed, I know that John @Shawspeed knows far more about the sigma engines than Alan does.
Alan Farmer is a recovery truck driver who spotted a niche, took a risk on setting up a business and it paid off, fair play, but he's not a talented engineer IMO, heis someone who learns on the job. Some of the bespoke work i've seen from there has been pretty 'industrial' to describe it politely.
Although I will say the work I had done was always decent although it was just routine stuff
John @shawspeed knows these engines better than anybody IME
for a cheap power increase,
if youve got a tape code ecu, get it reflashed to the frp map ( bloke on here does it, and some one on zsoc can do em to ) this raises rev limit slightly and removes first gear tourque limiter and will allow you to run frp ( ford racing puma ) cams,
this with your exhaust ect will give 145 ish bhp, after that, id be more tempted to go bak to a 1.6 as there is more cam choice and throttle bodies, or bin the engine and go 2.0
im in the same situation as you, although mine has the frp cams and remap, goes alright, quite good on fuel still but would benifit from the frp inlet, but like fuck am i paying 600 quid to gain 8 ish bhp lol
JoeyBoyden
Jan 4, 2024 02:36 PM
