Help zvh engine advice
Ive picked up a zvh engine and i haven't run it yet,it is supposed to be a mk1 rs bottom end,anyway to cut a long story short the engine is on a stand and im fitting a new cam belt and thought id check the engine by turning it by hand,anyway it turns fairly easy and then it goes hard then easy again is this right considering there's no belt on and the lifters are all undone too,your superior knowledge will be most helpful cheers....
Pete...
Pete...
Had a bit of an update,the engine was on an engine stand and i left the flywheel bolts in but one was slightly longer and so it caught as i turned the crank round.....hmmm school boy error....
blackbeautyzetec
Sep 11, 2015 03:10 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
