bottom crank pully removable
i need to get my bottom crank pulley off to change the cambelt on the zetec engine however the engine is on a pallet with no gearbox connected ,ive tryed locking up the fly wheel but when i try and leaver on the pulley nut it just lifts the engine up , any idea's?? fan belts already off as is the alternator and water pump pulley , just need the crank pulley off to change the cam belt so i can get it ready to fit in to the car
cheers
craig
cheers
craig
im in the same shop, you need to make a Y holder for the crank pulley (its what the two holes are in it for) im going down ford tomorrow to find out if thay sell one as my engines without a flywheel so ive only got this chioce or fit the engine and do it on the car.
DixieTheKid
11
Jun 6, 2020 11:20 AM
Fudgey
Sep 17, 2015 01:06 PM
