Rs turbo starting problem
Old Mar 22, 2012 | 09:00 PM
rs_jim's Avatar
rs_jim
Default Rs turbo starting problem
When the car is cold it struggles to start sometimes you have to the push the meetering unit flap down and eventually it will start I have change the cold start valve an it's connected I have changed the fuel black box with 3 others and still does the same thing ?
But when it's warned up it will start up first time ?
Old Mar 23, 2012 | 07:09 PM
jan247uk's Avatar
jan247uk
SE500 All Blue
i would check an make sure the cold start valve is squirting when your cranking first remove it and connect back up over a container thiers a few sensors around the back that could cause a poor start problem allthough saying that RST's are a bit crap at starting when thier right i have to crank a while and feather the throttle some before mine starts
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
nick8saff
Aug 16, 2015 05:35 PM
Zoggon
Aug 10, 2015 10:39 AM
Sjieter
Aug 5, 2015 09:47 PM
