Gizzmo boost controller/diff/ other bits inc rs500 fg bumper.
Having a clearout as the mrs keeps complaining about cossie bits everywhere!
Gizzmo MS-IBC boost controller. Covered about 500 miles until I decided to go aftermarket management and then it was no longer needed.
SOLD.
2wd Diff.. Great condtion, recently rebuilt. Would look great with a clean
Was running perfectly on my 3 door but changed to a low ratio unit.
SOLD.
Group A coil. Perfect working order.
£20+post.
Amal valve. Tidy..worked fine on car etc.
SOLD
Mint 3dr centre console ash tray. Would be fine for concourse. Never used.
£Ideas please guys????
3dr Rear washer bottle and working motor.
£15+post.
3dr Amp. Not tested. small mark on side (see second photo)
£10+post.
RS500 FG front bumper.. Good sturdy copy from unknown manufacturer
£180 collection only. (Or arrange your own courier..) Has been given a light primer to preserve front side.
Im located in west berkshire. Will not post abroad i'm afraid.
Thanks for looking
SOLD.
SOLD.
£20+post.
SOLD
£15+post.
£10+post.
Thanks for looking
Tell me more about the boost controller.... im learning every day with the cossie.
How does it fit and what are the benefits? I presume it bypasses the amal valve?
Huw
Yes mate.. It simply observes the 'pre boost' going to the actuator and controls it accordingly. You can control how fast it comes in and it holds boost very stable
you can store pre-sets etc do can have different boost levels at a touch of a button.
(As long as you have a suitable map for the boost!)
Yes, here you go mate.. A previous owner of the car had it done so I have covered his address at the bottom. (note the receipt tallies in with the tag on the diff)
I've just worked out the mileage and it's done just over 5k since the rebuild.
The car was a running 350bhp with this diff.. Then probably 2-3 hundred miles at 405bhp and was fine. Then I replaced it with my low ratio unit before upping the power again
CabrioTurbo
Aug 1, 2015 11:04 AM
Escortdriver1
Jul 31, 2015 02:36 PM
