will putting a de-cat on a car make the emmisions go sky high?
Old Mar 16, 2012 | 09:21 AM
paceo's Avatar
paceo
Cool will putting a de-cat on a car make the emmisions go sky high?
obviously i know it will put the emmisions up but roughly by how much? had my golf VR6 with a de-cat on the probe the other day and it was 0.75 on the co emmisions (fail), hydrocarbons was green as was lambda probe emmisions.
Old Mar 16, 2012 | 12:39 PM
paceo's Avatar
paceo
Old Mar 16, 2012 | 01:50 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
0.75 is not really sky-high when you bear in mind that old carburetted non-cat cars and bikes may have up to 4.5% CO.
So basically 0.75 sounds about right for a modern fuel injected car with the catalytic converter missing.
Old Mar 16, 2012 | 01:54 PM
STeve's Avatar
Super Moderator
does effect some cars more than others as loads of FRS models just breeze through with de-cats
Old Mar 16, 2012 | 02:10 PM
langer's Avatar
langer
It's also an mot failure now not to have a cat fitted
Old Mar 16, 2012 | 03:17 PM
JamesH's Avatar
JamesH
Completely depends on the car, as to what effect it will have.
Some modern engines now, chuck a load of fuel in on start up, to help ignite the cat and get it working (hot) quicker etc
Old Mar 16, 2012 | 03:34 PM
paceo's Avatar
paceo
its a golf vr6 mate
Old Mar 16, 2012 | 03:55 PM
langer's Avatar
langer
Iam sure that now even if your car passes its emissions but hasn't got a cat it will fail. Same as if your management light is on but it passes emissions it's a fail
yawiejon
15
Aug 9, 2015 06:36 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
