rs turbo no oil pressure light
Bodybuilding
From: Cannot be identified by the information given.
i have no oil pressure light at all, what could it be i have changed the bulb and have the wire connected on the pressure switch ?
iirc you can just put the wire on the switch to earth and the bulb should light up this will check the wiring and bulb etc if it lights its the switch at fault if not work backwards checking wiring as mentioned above
No, that is the ground for the bulb, but you should see power at it, if you don't then you have a bad connection or bad live to the bulb even.
If you do then the pressure switch is at fault, as said if you ground the wire and the bulb illuminates the switch is the problem!
Martin
Martin
big_Rad
Sep 15, 2017 09:36 AM
CrOwSoN15
18
Aug 22, 2015 10:24 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
