USA Focus RS Build.......for track days.
Old Mar 12, 2012 | 12:28 PM
thielt1's Avatar
thielt1
Default USA Focus RS Build.......for track days.
I thought I would bring USA build over to the UK forum since I am on here all the time and you guys are experts when it comes to questions I might have about the FRS.
Keep in mind this build has been taking place over the course of three years now, two of which were for sourcing parts.
Where it began:
To Here:
Old Mar 12, 2012 | 12:29 PM
thielt1's Avatar
thielt1
Door cards: (I will now be using these as the rears will need to be cut up a bit to fit the cage and I didn't want to have real rs cards sent here only to be cut up. I will be running euro handles with these.)
Old Mar 12, 2012 | 12:30 PM
thielt1's Avatar
thielt1
Front Bumper cut off, our bumpers are welded on where as yours bolt up:
New Bumper Mounting Plates Welded On:
Bumper On:
Old Mar 12, 2012 | 12:32 PM
thielt1's Avatar
thielt1
Rear Bumper:
Old Mar 12, 2012 | 12:33 PM
thielt1's Avatar
thielt1
Car in Rotiserrie for first time because new shop was being put up:
Goodbye Old Shop:
After an Entire Summer of putting it up Hello New Shop
Old Mar 12, 2012 | 12:34 PM
thielt1's Avatar
thielt1
Blasted and Primed underside:
This will be primed once more and painted after under coat is on and all cage and harness eye hooks are put into place
Old Mar 12, 2012 | 12:35 PM
thielt1's Avatar
thielt1
Blasted and painted all suspension parts being used:
thielt1's Avatar
thielt1
Urethane Bushings:
thielt1's Avatar
thielt1
Quarters off:
First Fit:
Old Mar 12, 2012 | 12:36 PM
thielt1's Avatar
thielt1
Inner Quarter Panels Cut Out: (I eventually had to remove more material then shown)
thielt1's Avatar
thielt1
Start of new inner panel:
Little farther:
thielt1's Avatar
thielt1
Primed Inners:
Old Mar 12, 2012 | 12:37 PM
thielt1's Avatar
thielt1
Rear Strut Bar:
Old Mar 12, 2012 | 12:38 PM
thielt1's Avatar
thielt1
Fitment Mock up before welding:
thielt1's Avatar
thielt1
Welding:
Old Mar 12, 2012 | 12:39 PM
thielt1's Avatar
thielt1
Sanding:
Old Mar 12, 2012 | 12:40 PM
thielt1's Avatar
thielt1
Here are the hood vents, I thought for what I was paying for these that they would come in trimmed and matching but I was wrong. These are WRC hood vents made from one of the original molds or at least they are suppose to be.
How they arrived:
Trimmed:
Close ups of Imperfections:
Fiberglass mud so I can even them out:
Old Mar 12, 2012 | 12:41 PM
thielt1's Avatar
thielt1
6 Point Cage now Installed:
thielt1's Avatar
thielt1
Hood Progress, Die lines:
1st cut made with air grinder and finished with die grinder:
Cut out the rest with 4 1/2" grinder and die grinder:
Both:
Vents sitting:
Old Mar 12, 2012 | 12:42 PM
thielt1's Avatar
thielt1
Finishing hood:
Welding in plates:
I might tack to the actual hood surface but not to much as I don't want it to warp.
Old Mar 12, 2012 | 12:43 PM
thielt1's Avatar
thielt1
Finishing up hood:
Prepped cage for paint, I don't think I posted a picture of the cage arms yet. These were the ones I had to weld to make this a bolt in cage.
thielt1's Avatar
thielt1
Hood just about ready for paint:
Car getting ready to be moved for paint:
Underside:
Old Mar 12, 2012 | 12:44 PM
thielt1's Avatar
thielt1
Moving along, Primed:
Cage:
thielt1's Avatar
thielt1
Interior and roll cage paint:
RS Rad Fan:
Bottom:
Old Mar 12, 2012 | 12:45 PM
thielt1's Avatar
thielt1
Wheels arrived!
Rad Fans Refurbished:
Old Mar 12, 2012 | 12:46 PM
thielt1's Avatar
thielt1
If I was flush with cash this would be done! I agree with the weight though.
Not a huge update but I replaced the allen bolts on my cam gears for hex bolts and polished away the massive purple.
I also split my gearbox (3rd synchro was bad when I bought it) I think I am going to change 1st and 2nd gear to the RS spec if I can as they were taller gears.
Matt Baxter's Avatar
Matt Baxter
Back in black!
Looking awesome that, will you be running a rs engine?
Old Mar 12, 2012 | 12:48 PM
thielt1's Avatar
thielt1
Engine:
Started test fitting the turbo kit:
Here is the parts List for what came with the kit, some things will change:
This kit made 396Whp/372Wtq @ 24psi on 93 octane
TopSpeed Turbo RACE Manifold
Garrett GT2871R Turbo (4" anti-surge compressor housing & T25 Plus v-band outlet turbine housing .63 A/R)
-4AN Braided Stainless Turbo Oil Feed Line (includes all necessary AN fittings and line from block to turbo)
-10AN Braided Stainless Turbo Drain Line (includes all necessary AN fitings and line from turbo to oil pan)
-6AN Braided Stainless Turbo Coolant Lines (both inlet and outlet with necessary turbo fittings/lines from turbo to coolant lines)
Zetec Oil Pan (with -10AN fitting and stat-o-seal washers already installed for turbo oil drain connection - leak free)
TopSpeed 2.5" Stainless Downpipe (v-band - turbine housing to flex pipe)
TopSpeed Stainless Dump Tube (v-band, works with included Tial 38mm MVS Wastegate)
Tial 38mm MVS Wastegate (blue)
Tial 38mm MVS Wastegate Spring Set (all 6 springs, from 4.35psi - 24.66psi)
Greddy Type RZ BOV (grey)
2.5" BOV Tube (Greddy style 2-bolt flanged tube)
TurboXS Manual Boost Controller
Garrett High Density Intercooler Core w/ATP Cast End Tanks
Siemens Deka 60lb/hr Fuel Injectors (4)
Diablo MAFia
All 2.5" HOT side aluminum tubing, silicon couplers, hump hoses, stainless t-bolt clamps (turbo to intercooler)
All 3" COLD side aluminum tubing, silicon couplers, hump hoses, stainless t-bolt clamps (intercooler to TB)
4" Hi-Flow Cone Air Filter (includes 45 degree silicone coupler, tubing and clamps)
Old Mar 12, 2012 | 12:53 PM
thielt1's Avatar
thielt1
Thought I would make it to the end without someone posting..........almost.
To my understanding when the RS was being built Ford sent over three test engines to Michigan for ? None of these three were ever put into anything so all they ever saw was dyno time. This engine is one of those three.
thielt1's Avatar
thielt1
I recieved an update from my painter today, all parts I dropped off are prepped and primed. Car will be getting dropped off today to get prepped and primed. Hopefully car will be fully painted by next week. I will try and get some pics tonight of the progress.
Also I just located a RS Gearbox and someone willing to ship it!
Both will be sent to Haines Motor Sports Inc for inspection and rebuilds.
Old Mar 12, 2012 | 01:04 PM
Andy Tucker's Avatar
Andy Tucker
Welsh And Proud
looking good there mate
Old Mar 12, 2012 | 01:13 PM
Pete frst's Avatar
Pete frst
Great to see Rs's stateside and yours is looking good,keep us updated
Old Mar 12, 2012 | 02:09 PM
Matt Baxter
Back in black!
Opps sorry,
Looks like a nice project I guess that the focus rs didn't make it over there then? What about the mk2 frs do you get them over there?
Old Mar 12, 2012 | 02:22 PM
thielt1's Avatar
thielt1
Neither
The MK2 can't even be built as a replica over here because the platform never made it. The only people have a mk2 over here are Ford Motor company (2 or 3 test cars), Ken Block, and a guy who I think has dual citizenship with mexico.
With the latest focus we might have a shot at a FRS along with you in 2015
Old Mar 12, 2012 | 05:51 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
where you based in the usa buddy ?
did you go for 9 j team dynamics ?
like dicko put on his ?
Old Mar 12, 2012 | 06:47 PM
thielt1's Avatar
thielt1
Wisconsin about 15 minutes from Road America.
The Specs on my TD are 18x8 et35, I didn't want to go with the 9" width because I haven't heard any real benefits on them for track use. Tires should be a little cheaper on the 8's as well.
The 9's do look agressive though!
Old Mar 12, 2012 | 07:04 PM
nevsrevs's Avatar
nevsrevs
top marks mate, is jeepers kreepers behind your work shop? lol
Old Mar 12, 2012 | 11:10 PM
McGoo 69's Avatar
McGoo 69
awesome build im loving the effort youve put in to make this a rs!
Old Mar 13, 2012 | 11:59 AM
thielt1's Avatar
thielt1
Thanks for the comments guys!
Old Mar 15, 2012 | 08:04 PM
MK5RS2K's Avatar
MK5RS2K
on you come!
very very nice,keep up the gd wrk
