cossie still not starting :-(
tried starting the car today, it's struggling to start but did start for about 15 seconds, but when you give it a bit of throttle it cuts out straight away. when it cuts out theres a horrible sparking noise coming from the distributor, WTF is that about.? ive had a new crank senor, new phase sensor new leads and new plugs fitted, still no joy,
Pull the dizzy cap and see if there's anything left on the contact points,the cap could have cracked as well and the noise you speak of sounds like arcing to me.check the security of the rotor arm,you could pull the cap off and get someone to crank the engine to check it's turning ok(dizzy drive not failed).
After that it's going to need a deeper description and some photos or booking in at a tuners.
i'll dig a bit deeper today. the car was setup by mark at MAD in july, and since then its only been to ford fair and back to north devon.
the car has been sat around since september and it hasnt been garaged :-(
Karl 3dr
102
Oct 14, 2016 08:17 PM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
