Bike engined FWD car?
Old Mar 1, 2012 | 05:26 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Default Bike engined FWD car?
For some reason I have a hankering to build a small bike engined car , how would you go about getting the drive from the engine to the driveshafts?
Obviously you need to retain a diff in there somehow?
Old Mar 1, 2012 | 05:34 PM
vaughant's Avatar
vaughant
Try searchin PPC(practical performance car) online as there was a mini with this done years ago using a fireblade engine.
Old Mar 1, 2012 | 08:22 PM
dingla rs's Avatar
dingla rs
its much more fun in the back mate ,its quite easy really plenty companys have off the shelf parts to make them ,as grass tracking specials run bike engines but mainly in back. google it
Old Mar 1, 2012 | 08:31 PM
daz1968's Avatar
daz1968
Z cars minis look good but the parts they sell are expensive really, sure a lot could be self fabricated, they do sound good though, think you need a very light small car to get the best from a bike engine, the one I seen still had a short chain drive from the bike gearbox that connected to the rear diff,
Old Mar 1, 2012 | 08:58 PM
Mark V8's Avatar
Mark V8
Would be nice if you could connect the bike engine output shaft to the input shaft on the car gearbox.
You would get the 'normal' car driving experience with reverse gear and syncromesh for day to day driving along with a fully sequential 6 speed dog box for fun
Old Mar 1, 2012 | 09:09 PM
RWD_cossie_wil
The only problem with that is you lose the step down from the engine to the axle sproket.
Old Mar 2, 2012 | 05:57 AM
daz1968's Avatar
daz1968
Think you can get a reverse kit for the axle set up on z cars, not really looked into what it does, but the sequential box on the bike engine is half the experience.
Old Mar 2, 2012 | 11:28 AM
Mark V8's Avatar
Mark V8
In theory you would not need it.
Just leave the bike gearbox in the most suitable gear and then use the car gearbox as normal.
Old Mar 2, 2012 | 01:35 PM
RWD_cossie_wil
But you lose the entire reason for doing the conversion then, the lovelly sequential gearbox!
Old Mar 2, 2012 | 05:43 PM
Mark V8's Avatar
Mark V8
No, you get the best of both worlds
You can leave the sequential box in a suitable gear and use the car box for day to day stuff / reverse.
Also you can stick the car box in a suitable gear and then use the sequential box if you fancy a thrash or a track day.
You would have 30 forward gears and 6 reverse
You would need to sort out a solenoid paddle shift or extra lever for the bike box and there would be extra frictional losses running two boxes.
JoeyBoyden
Jan 4, 2024 02:36 PM
Davemurphy007
Motorcycle Chat & Sales
Aug 14, 2015 05:58 PM
track.focus'd
Aug 12, 2015 05:53 PM
knight19770
Aug 4, 2015 12:36 PM
