Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
xflow sump fitment
Old Feb 22, 2012 | 06:39 PM
cosrj's Avatar
cosrj
Default xflow sump fitment
wondering could anybody help me out does a 1300 x flow sump fit on to 1600 x flow engine?
Old Feb 22, 2012 | 06:40 PM
kev 3dr's Avatar
kev 3dr
yesit should do
Old Feb 22, 2012 | 07:01 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Yes it will, the only difference between the two is the rods and slightly different pistons iirc.
Old Feb 22, 2012 | 07:07 PM
cosrj's Avatar
cosrj
ah rite cause ive been told 1300 fit but it has to be dished down bit more or the crank can rub cause it not as deep as the 1600 one any truth in that? lol
Old Feb 22, 2012 | 07:14 PM
cossie ken's Avatar
cossie ken
The 1600 block is slightly taller than the 1300 but the sumps are the same mounting pattern and interchangeable. If you are using a front sumped engine from a Cortina and fitting a sump from an Escort you will also have to change the pick-up pipe and the dipstick position, but thats easy done.
Old Apr 22, 2012 | 07:04 PM
powerband's Avatar
powerband
yes u do after dish a 1300 sump out slightly best thing to do is fit sump dry with out gasket turn engine over by hand then u will see marks where crank catches take off dish out refit jod done
Old Apr 23, 2012 | 04:59 PM
retrofab's Avatar
retrofab
a 1300 would have to be modified to fit because the bigend bolts will foul the side of a 1300 sump. if you look at the side of a 1600 sump you will see small bumps outwards for clearance.best solution buy a 1600 off fleabay or else get a hammer and dolly out and start hammering.
Iain Mac
Sep 30, 2015 09:39 PM
youngben
Sep 27, 2015 09:37 PM
little bram
Sep 21, 2015 02:50 PM
BRAM
Sep 8, 2015 07:11 AM
little bram
Sep 7, 2015 11:59 AM
