help please will sierra 2.3d fit 1.8td p100
Old Feb 17, 2012 | 08:57 PM
fordp100man's Avatar
fordp100man
Default help please will sierra 2.3d fit 1.8td p100
Hi all major problems my gearbox has broke on my beloved p100.will a sierra 2.3 diesel fit my 1.8 td.if so will there be any diffences thanks jack
Old Feb 17, 2012 | 11:34 PM
vaughant's Avatar
vaughant
Think so mate,aren't they both type 9 boxes?
Pretty sure all ford boxes bolt up to all ford engines.
Old Feb 18, 2012 | 08:05 AM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
bellhousings and starter are different 2.3 is a pug engine
everything else will swop over provided you have the donor car
Old Feb 18, 2012 | 08:14 AM
fordp100man
Well I've got my old gearbox for the bell housing what do toy mean by starter.The sierra is in a scrapyard.
Old Feb 18, 2012 | 08:41 AM
Cossie Sean
i *think* you can put a normal petrol non V6 type 9 onto the TD bellhousing and will bolt up perfect and obviousley retain your TD specific starter etc!
from memory,
bellhousing is different shape and doesnt bolt on
input shaft on gearbox of 2.3 is longer than 1.8TD one
starter motor is in different place on 2.3 than a 1.8TD one
2.3d bellhousing (gearbox end is from another make, not ford g/box)
Old Feb 18, 2012 | 08:44 AM
Bailes1992's Avatar
Bailes1992
Yeah the 2.3 is a Pug XD2, there was a turbo charged version called the XD2s. Terrible engine infact.
Old Feb 18, 2012 | 08:46 AM
Cossie Sean
theres a few p100`s breaking on ebay.
wont cost you anything to message them to find out cost of correct gearbox
http://www.ebay.co.uk/sch/i.html?_nk....c0.m270.l1313
Old Feb 18, 2012 | 09:29 AM
fordp100man
Thanks for all your help.will need a Ford one then.i hae contacted those ones from eBay but they are so far away.
Old Feb 18, 2012 | 10:00 AM
3FRD's Avatar
3FRD
Use Paisley Freight they're cheap for delivery
Old Feb 18, 2012 | 10:17 AM
fordp100man
Just spoken to a gearbox specialist he says the bell housing is diffent.but the shaft is the same can anyone shed any light on this please!
Old Feb 18, 2012 | 02:05 PM
fordp100man
Anybody??
Old Feb 18, 2012 | 02:33 PM
Cossie Sean
1.8td is different length to the 2.3 one, but the same as any non V6 petrol
Old Feb 18, 2012 | 05:48 PM
Marcyg's Avatar
Marcyg
You're better off sticking a 1.8 back in it, the 2.3 was awful and goes through fuel likes it's going out of fashion. The 1.8 is faster too
Old Feb 18, 2012 | 06:16 PM
fordp100man
True its just I cant get hold of a 1.8 gearbox.i can only get a 2.3 from a nearby scrappy.any more info would be great
Old Feb 18, 2012 | 06:45 PM
Cossie Sean
i wouldnt do it with a 2.3 box as the ratios are horrid
unless you get the complete gearbox, machine the input shaft, play with clutch drive plate combinations, fit the 2.3 starter and wiring for the relocated starter motor, and clutch cable assembleys etc.
i would check the propshaft splines before you get the 2.3 aswell
it just isnt worth it in me eyes
if it just boils down to not wanting to spend Ł150 delivered
on the correct box then say so (i messaged a few people on ebay and 2 were this price)
Old Feb 18, 2012 | 07:23 PM
fordp100man
Thanks mate will wait for a gearbox
Toms Grende
13
Aug 22, 2015 03:39 PM
markk
18
Aug 17, 2015 05:19 AM
Vincereese
Aug 15, 2015 06:24 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Vincereese
Aug 11, 2015 08:44 AM
