my budget ford fiesta mk 5 hybrid 2.0ltr turbo
I purchased a mint 1.3 mk 5 ford fiesta in sliver from one of my friends with Zetec s bumpers and side skirts
then after i while i i found a set of rs2000 wheels and got them freshly painted by Dave at county car sprays i
also fitted a set of 60mm lowering springs and she was looking good then after little while i bust the
head gasket in the winter but it was only the water jacket to outside the block so after 3 months of
toying with ideas i decided to to go with a engine upgrade my mate dave had a mint mk3 Mondeo estate
turn up form his other halves uncle full service history and all it really needed was tax so me and Dave being
who we are decided to take out the 2.0l engine and put it into my fiesta so we took out the broken 1.3 engine
and rough fitted the 2.0l to see if she will fit after a few body mods and engine mods we know had a 2.0l engine with no
power steering no air-con a rs fiesta flywheel and clutch and a 1.3 endura gear box we spaced and modded the engine mount and
gear box mount so she was sitting level, manged to get our mate Matt who is more then a dab hand at electronics
to wire up a mk 2 pre pac system ecu and wireing loom she had a few running problems but they all ironed out and dave fought
we might aswell use the mondeos brakes for my car to say buying uprated parts and dave set about making it happen and she
was built. After 4-5 months i had melted 2 clutches, but one night i was driving her and bang the drive shaft escaped
the cup and put a sizable hole in my sump dumping all her oil everywhere after getting dave to tow me home we started to think,
all 3 of us joked about using Daves spare turbo parts to build a all ford hybrid this was just the spark we need to start the fire.
so i left my poor fezzy at home took her engine out and bought it to county car sprays ( Daves workshop ) and Que the music.
a full strip down new internals a few bits from ebay and Daves spares bin a trip to the RS centre some hoses from graham and
electrics done by matt alot of patients from daves fiance who was 5 months pregnant at start and given birth during the build
and i had a unique fiesta her name is Christine and she is my budget ford hybrid 2.0ltr turbo
the specs are as follows
2.0ltr Mondeo sliver top stripped and rebuilt
manual steering rack
custom auxiliary belt
custom water pipes
HKS airfilter
baileys dumpvalve
3ft x 1ft intercooler ( i carnt remember the make )
1.8ltr sump with oil return and oil breather lines made from hydraulic hosing
5mm decompression plate with 2 high grade head gaskets
RS2000 inlet manifold
Zetec to CVH exhaust adapter plate
escort rs turbo manifold and garret t3 stage 2 hybrid turbo in a 42 housing
RS turbo fiesta flywheel and race road clutch
oil catch tank
fuel regulator
1.3 gear box and drive shafts
RX-7 rear swing arm mount for extra stability on engine mount
modified engine and gearbox mounts
RS1800 radiator
10' fan
2.0ltr Mondeo pre-pac desk ECU with blue super chip
as well as the 1.3 ECU
full zetec s bumpers with side skirts
custom front splitter and rear diffuser
RS2000 wheels now OZ super tursimos
standard shocks with 60mm lowering springs
195/50/15 fronts
195/55/15 rears
2.0ltr Mondeo front discs pads and calipers
2.5'decat exhaust with resonator and silenced 3'back box
mk3 fiesta si wing back seat with 3 point sparco harness's
full set of carbon firbre door cards
boost water temp and fuel to air ratio gauges
mk 3 fiesta center console and relocated cd player
stripped interior
custom cardboard speaker box ( i didn't wanna cut holes in door cards )
cheeky flamer kit
washer jets in front bumper to cool rad and inter cooler
custom water pipes
HKS airfilter
baileys dumpvalve
oil catch tank
fuel regulator
RS1800 radiator
10' fan
195/50/15 fronts
195/55/15 rears
stripped interior
cheeky flamer kit
I got front a rear arches from another fez that i cut off :P and I'm Gunna flare out my original aches and then weld the other aches on so they look original but and extra 1" 1.5" wide with spacers on wheels to give it a bit more stance
James
Dam sounds like alot of fucking about man, got pics of it finished ?
James
James
and with the lip back on n primed
Not perfect yet needs a little more smoothing but looks waaaaay better than standard. only regret is I effectively raised the distance between the wheel n arch as i slit it and then hammered it out and upwards. so atm with no weight in car it looks jacked up lol. but coilovers will sort that.
it was a swine to smooth them. if i had choice to do it again id fab a whole arch before fitting it n then just weld it on with minimal filler. but if i get hit in the arch then its gonna be messy!!!!
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
