Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
2.0 blacktop into mk5 (zs)
Old Feb 5, 2012 | 02:45 PM
Big_Mike's Avatar
Big_Mike
Default 2.0 blacktop into mk5 (zs)
Anyone done this?
Is probably possible, just can't think of what gearbox to put in, as mondeo gb will be too big and is cable operated
cheers
Old Feb 12, 2012 | 04:06 PM
Churtz's Avatar
Churtz
Originally Posted by Big_Mike
Anyone done this?
cheers
ive got a 2.0 focus lump in a mk4 - so basically the same as mk5. Its got a silvertop cam cover and inlet but its a blacktop lump.
Im using the gearbox from a 1.3 endura mk4 fiesta, so it mates straight up to the box mounts, and also puts the starter under the inlet at the back.
Matt
Old Feb 12, 2012 | 09:54 PM
Big_Mike's Avatar
Big_Mike
Matt
Top man, thank you for the advice! That sounds like a plan. Was there any modifying of engine mounts etc?? And also, what sort of power are you running, and what would the gearbox take?
Thanks
Old Feb 16, 2012 | 08:38 PM
Churtz's Avatar
Churtz
Running around 200bhp with 7psi from an eaton supercharger. Gearbox seams to e holding up but I'll rebuild the internals with st150 gears when it fails.
Had to make an engine mount for the osf.
Matt
Old Feb 17, 2012 | 06:03 AM
Tomfezza's Avatar
Tomfezza
any photos or project build ? would like to see this !
Old Feb 20, 2012 | 10:47 AM
Big_Mike's Avatar
Big_Mike
Matt
Sounds good to me, and a pretty cheap conversion, as you can pick up a blacktop for about Ł200!
Sounds pretty good to me, what diff are you running?
Pop some photo's up if you could, would love to see this build!
I second this!
Old Feb 24, 2012 | 07:01 PM
Churtz's Avatar
Churtz
I'll get some pics up as soon as poss chaps.
Matt
mk3ste
Oct 17, 2021 10:09 AM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
The Enigma
Sep 29, 2015 10:31 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
Chopshop85
Sep 12, 2015 06:42 PM
