Mondeo mk3 heater control problem
Old Feb 3, 2012 | 07:03 PM
RyanML's Avatar
RyanML
Default Mondeo mk3 heater control problem
hey all,
I have a mk3 mondeo tdci facelift (53plate) and I have a problem with my heaters, they heat up fine but i cant stop them from blowing on the windscreen, cant get them to blow at me or my feet, any ideas what the problem could be? the buttons on the heater control unit lights up when pressed as they should but the hot air wont change direction, ive done a quick search but cant seem to find the problem is
thanks for any help
Old Feb 3, 2012 | 07:09 PM
RS500/364's Avatar
RS500/364
Could be to do with the heater resistor can cause a problem dont know if this is one of them but its were the water goes in around the pollen filter down to the motor shorting out the resistor replace may cure
Old Feb 3, 2012 | 08:55 PM
martysmartie's Avatar
martysmartie
Clearly the motor is working fine, rather the problem is being unable to change the direction of the output, if it's cable operated maybe the cable has broken thus stuck in the one and only current position?
Martin
Old Feb 4, 2012 | 10:08 AM
kieran265's Avatar
kieran265
hi i have the same problem,
still not found a cure so if anyone could help us both would be good
thanks kieran
Old Feb 4, 2012 | 05:40 PM
GVK.'s Avatar
GVK.
These have motors to control the flaps, sounds like the panel has failed.
Old Feb 5, 2012 | 09:42 PM
RyanML's Avatar
RyanML
the control panel with the buttons on? im going to scrap yard tomorrow see if i can get one cheap to try
cheers!
Old Feb 5, 2012 | 09:55 PM
GVK.'s Avatar
GVK.
yes, they are fun to remove as well! Have to take half the dash out to get the panel off!
Rob Wells
Apr 18, 2023 12:19 AM
Kyle Langford
27
Aug 5, 2019 07:54 PM
RSBryden
Sep 6, 2015 08:39 PM
Bighandsuk
Sep 2, 2015 05:23 PM
