Getting 8" wheels under 3 door front arches
Old Jan 29, 2012 | 05:48 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Default Getting 8" wheels under 3 door front arches
Have got a set of 8" front wheels for the 3 door, but the tyre catches the front bumper, what the modification people do the pull the wing out at the bottom by the bumper corner?
Old Jan 29, 2012 | 06:07 PM
BRAMMER's Avatar
BRAMMER
Think they drill the rivets and put washers between
Old Jan 29, 2012 | 06:09 PM
Steve the Plumber
Cheers Chris, Im trawling through Ronnies thread to see what he has done.
Old Jan 29, 2012 | 06:22 PM
mark r's Avatar
mark r
i just managed to 225 35 on an 8" up front
Old Jan 29, 2012 | 06:36 PM
Sonic Boom's Avatar
Sonic Boom
What size tyres are you running mate?
I've got 8 x 17 ET33 with 215/40/17 and they don't catch the front bumper.
Rich
Old Jan 29, 2012 | 07:21 PM
Steve the Plumber
Rich, balloons compaired to yours! I think they are 245 45's
Old Jan 29, 2012 | 08:12 PM
Sonic Boom's Avatar
Sonic Boom
245/45's on the front!
Jesus Christ! What you got on the rears 315''s?
Rich
Old Jan 29, 2012 | 08:13 PM
johnyjn's Avatar
johnyjn
I have 205/40/17 r888 on a 8x17 et35 on the front and they don't catch at all.Why do you need such a bigger tyre on the front ?
Old Jan 29, 2012 | 08:15 PM
Gav Diamond's Avatar
Gav Diamond
This has been spaced 30mm and runs 235.40.17 tyres, on my own car I only spaced them 10mm so it still looked standard
Anti roll bar plays a big part too.
On the H13 (standard 3dr bar) I had no issues but on the H14 (2wd saff bar) I had to trim the bumper and splitter, mind I did put 10mm wheel spacers on to widen the front track too.
Thats with 215.40.17's
Old Jan 29, 2012 | 08:39 PM
Steve the Plumber
Rich
LOL and nearly on the rears!!
Have just bought 8" front and 9" rears, looks like i'd better get some more tyres before pulling the wings out!!
What tyre sizes would you recomend for 8X16 fronts and 9x16 rears, preferably R888 Toyos?
Cheers guys!
Old Jan 29, 2012 | 08:56 PM
RONNIE AMIS's Avatar
RONNIE AMIS
Hi Steve. I spaced the front wing like the picture above. Then Dave made them arches for me for a quick fix. That was to run 235/40/17's. On 9x17's some standard arches might work just cut right back
Old Jan 29, 2012 | 10:40 PM
jason_nike's Avatar
jason_nike
New wheels Steve, what you got now?
Old Jan 30, 2012 | 10:47 AM
rinus_2005's Avatar
rinus_2005
i got8x17 et33 with 235/35 r17 (almost, it's 235/ and a outside diameter of 610mm) at the front, and took some major cutting out the wings (about an inch) and removed the inside edge of the plastic arches (also the mouning points) so i bonded them on.
Want to space out the arches at the front, but noticed that while widening at the front, it would deform a bit and pull the top actually inwards. (due loosing strength when i cut the inch away) i'll see if ihave some pics.
Before cutting, and camber not yet adjusted
Old Jan 30, 2012 | 03:06 PM
Steve the Plumber
Cheers fellas,
Looks like I need slightly smaller tyres 1st!!
Jas, Ive got another set of Grpa 5 spoke revos, 8x16 fronts and 9x16 rears, and with the wrong tyres, they really do fill the arches up!!
Old Jan 30, 2012 | 08:17 PM
Ridgey's Avatar
Ridgey
Steve i run 8x16 all round on 225/45 R888, so i'd go for that size on the front.
For the rears not sure you'd have to check available sizes 235/45 maybe? or 245, 255/40's ????
Old Jan 30, 2012 | 08:25 PM
mk2cossy's Avatar
mk2cossy
Ive got 9's all round 225/35/17 front and 245/35/17 rear.
Old Jan 30, 2012 | 08:27 PM
mk2cossy's Avatar
mk2cossy
Who's got the E50's?
Old Jan 30, 2012 | 09:25 PM
Gav Diamond
His name is Lincoln but he doesn't come on here anymore, he is from Australia.
Do you have any pics of the 225.35 tyres mate as was thinking of going this size
Old Feb 3, 2012 | 07:08 PM
Ridgey's Avatar
Ridgey
I run 225/35 17's on my road wheels, pictured below:
Old Feb 3, 2012 | 07:37 PM
Steve the Plumber
Thanks Ridgey, looks good in action mate!
Old Feb 4, 2012 | 08:34 AM
Craig J's Avatar
Craig J
Steve
I run 225/45R16 with ET30 on the racecar and have had to trim flange off the bodykit, roll the arch flange, trim some of the arch nearest the rear wheel and also trim back some of the bumper flange. You can gain more clearance running eccentric top mounts and if you don't then you need to be careful if you use adjustable lower arms because you can widen the track to gain camber and start to rub. As mentioned the castor setting can influence too. Best thing you can do is mount your damper without the spring and articulate the wheel to check where you will have issues. Cheers
Old Feb 4, 2012 | 12:59 PM
Steve the Plumber
Thanks Craig.
Old Feb 4, 2012 | 02:22 PM
BRAMMER's Avatar
BRAMMER
Steve have you got a standard style front ARB? as i have one mine and i get more scrubbing on the right than the left and odd coil over height settings, so when speaking to Mr linfoot he explained the reasons why on a 3dr - it being down to the ARB being out of line something to do with cornering so just something to check as it may give you a couple of mm if it is out (if you know already or run comp strut's ignore me lol)
Old Feb 4, 2012 | 02:35 PM
Steve the Plumber
Cheers Chris, yep standard ARB and it only catches the bumper on the OS.
Im gonna change the tyres first before doing any "trimming"
jessie_rs
11
Jun 3, 2019 04:57 PM
3i Jim
Nov 20, 2015 05:12 AM
track.focus'd
Aug 12, 2015 05:53 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
Old ford
Jul 31, 2015 06:50 AM
