MK 2 Golf gti wont re-start after breakdown
Old Jan 28, 2012 | 01:26 PM
siddleg's Avatar
siddleg
Default MK 2 Golf gti wont re-start after breakdown
My mk 2 golf gti 90 8v which has been fully serviced last June with new leads, plugs dizzy, arm, coil, oil and filters started juddering badly today then broke down and the RAC man came and couldn't get it started. He checked the leads and found the king lead damaged, the porcelin had snapped off into the dizzy and then some of the leads had been arching badly in the dizzy so that was renewed and the leads. I turned it over and it never started to our surprise, so he checked for spark which there was and checked the fuel rail which had fuel pumped to it so with both our heads scratching the car was towed to my local garage. what could it be? it has a cobra immobo but has never caused any probems before and surely it would cut something out?
any advice would be great thank you
Old Jan 28, 2012 | 03:00 PM
martysmartie's Avatar
martysmartie
It has a spark at the king lead but what about at the HT side, rotor arm good?
Yes immobiliser would cut fuel/ignition, you have both so it isn't that!
Martin
Old Jan 29, 2012 | 10:44 AM
siddleg's Avatar
siddleg
yes all leads have spark and arm was only changed last June so.
cheers
Old Jan 29, 2012 | 10:57 AM
martysmartie
Spark at the plugs? And is there fuel past the injector rail?
Martin
Old Jan 29, 2012 | 11:01 AM
RichieST's Avatar
RichieST
Have you checked the timing?
Old Jan 29, 2012 | 03:50 PM
siddleg's Avatar
siddleg
That's something the garage can check tomorrow.
cheers
Old Jan 30, 2012 | 04:14 PM
siddleg's Avatar
siddleg
timing is spot on, compression's are good. They got it started but runs really lumpy and sometime wont re-start.
anyone?
Old Jan 30, 2012 | 05:16 PM
martysmartie
Good fuel and fuel filter?
I don't know the first thing about them, i.e. the fuel setup etc, from what your saying I would say it's EFI?
You/they need to assertain exactly what is happening to cause it to cut out, i.e. is it running rich etc?
Martin
liamT74
Sep 23, 2015 10:24 PM
jonnyenglish
Sep 21, 2015 07:31 AM
jc1989rs
Sep 18, 2015 07:05 PM
cossirob
Sep 16, 2015 07:39 PM
nikki.n.tom
Sep 15, 2015 08:20 PM
