Trouser Studs
Jan 22, 2012 | 07:47 PM
Trouser Studs
What studs are used to join the trouser section on a 2wd manifold, are they the same as turbo to manifold studs.
Jan 22, 2012 | 08:13 PM
Not studs they are special bolts, they used to cost £8 each from ford when you could still get them.
Jan 22, 2012 | 08:19 PM
Dose any one do them now, what was special about them.
Jan 22, 2012 | 08:20 PM
Jan 22, 2012 | 08:36 PM
Quote:
Originally Posted by
jamie956
They don't snap / go brittle when the get hot. Try one of the breakers on here to get some.
Jan 22, 2012 | 08:47 PM
Id of thought that 12.9 cap heads would be strong enough?
Jan 22, 2012 | 08:56 PM
whizzisat114
It's not about strength, it's about the ability to withstand the heat cycles they'll go through, I think Cosworth put some thought into this
Jan 22, 2012 | 09:00 PM
Does anyone know what to ask for then?
Jan 23, 2012 | 12:14 PM
Can you get them in different lengths, as i have a trouser piece spacer as well.
Jan 23, 2012 | 03:51 PM
From: Under the water.... .......in a nuclear submarine
jamie956
They are made of Inconel............same as F1 exhausts. Hence the price
Jan 23, 2012 | 05:08 PM
How about the studs that join the turbo to the manifold, what are they made of thats what i was thinkin about using.
jessie_rs
62
Aug 6, 2019 09:27 PM
Cosnada
Jan 7, 2016 05:30 PM
IainRS1700T
Sep 25, 2015 06:44 AM
coscor86
Sep 20, 2015 01:21 PM
