Help! Saff boot will not open
Old Jan 9, 2012 | 08:20 PM
lynnsy's Avatar
lynnsy
Default Help! Saff boot will not open
Any tips for getting into a saff boot.
Mine has RCL through alarm, it used to lock/unlock the bootlid
However not now, and the key will not unlock it either!! ahhhhhh
What to do???????
Old Jan 9, 2012 | 08:22 PM
Dan_RS500's Avatar
Dan_RS500
You get a torch and a screwdriver and climb in from the rear seat and push the lever on the lock/catch with the screwdriver.
Old Jan 9, 2012 | 08:28 PM
lynnsy's Avatar
lynnsy
Its a cossie with leather and I cant seem to get into the boot that way, or I am stupid?
Old Jan 9, 2012 | 08:29 PM
Cossie Helen's Avatar
Cossie Helen
As Dan says, as this happened with my Cossie and thats the only way I could open boot!
Old Jan 9, 2012 | 08:32 PM
martysmartie's Avatar
martysmartie
The seats do have a 60:40 split arrangement, trouble is the levers to release them on Saphs are accessible via the boot
I presume it's delocked?
You can either try and sort the remote locking, unless it's a problem with the motor in which case you still need to access the boot, or alternativly try and lower the seats from within the car to get access.
Martin
Fordmad!'s Avatar
Fordmad!
Happened on a few of my cars and this is the only way unless you can unbolt the latch from the inside. Will come open with a screwdriver tho!
Old Jan 9, 2012 | 08:37 PM
BigErn's Avatar
BigErn
remove a rear speaker if you can and get your arm in the hole to pull the seat release then crawl in and open the boot
Old Jan 9, 2012 | 08:40 PM
lynnsy's Avatar
lynnsy
Cheers boss, ill try that
Eigdoog's Avatar
Eigdoog
ą§~Quadzackular~§ą
Sorry but PMSL! This happened to me but my rear lights were out so no problem there lol.
Old Jan 9, 2012 | 08:41 PM
Dan_RS500's Avatar
Dan_RS500
Aye thats right, the seat release is in the boot, I remember now! You have to remove the lower part of the seat, it just pulls out with the cloth ones, I'm not sure with leather though. Then you should be able to unbolt the seat backs from the hinge and make a big enough gap to get your arm in and up to pull the release.
martysmartie
By the above we are assuming your car is actually delocked? If not you can unlock with the key in the lock.
Martin
Old Jan 9, 2012 | 08:42 PM
Dan_RS500's Avatar
Dan_RS500
Wish I'd thought of going in through the speaker when it happened to me! Good thinking fella!
Old Jan 9, 2012 | 08:43 PM
Dan_RS500's Avatar
Dan_RS500
Martin
He says the key will not unlock it either.
Old Jan 9, 2012 | 08:52 PM
iansoutham's Avatar
iansoutham
OCD Victim
Spray a small amount of WD40 into the boot lock and carefully try wiggling the key to see if it can move as people do not use them enough and they tend to seize up.
Don't force the key though or it could snap in the lock itself.
Old Jan 9, 2012 | 09:24 PM
stevieturbo's Avatar
stevieturbo
C**t
If youre incredibly small and flexible, isnt there an opening behind the arm rest ?
Although I recently had to force my way past the rear seat ( pass side ) to get access to the boot to open a friends. Didnt do any real damage worth talking about. Was easier than I expected.
Old Jan 9, 2012 | 09:33 PM
cossiestu's Avatar
cossiestu
I disabled the seat catch when I delocked mine, just incase the lever next to the seat fucked up... Not wanting to piss on your chips, but I thought the speakers screwed in from inside the boot too!? Although, I guess a broken speaker wouldn't be as bad as smashing the rear light out if it came to it!? Good luck with it!!!
Old Jan 9, 2012 | 09:34 PM
martysmartie
My bad, as we were lol!
Martin
Old Jan 10, 2012 | 09:12 AM
R4N SS's Avatar
R4N SS
thats what ive had to do when my boot hasnt opened
Old Jan 10, 2012 | 09:46 AM
cozmeister's Avatar
cozmeister
More boost Igor!
Thinking a bit further ahead, once you've gained access to the boot, remove the lock (takes about 5 minutes with a screwdriver and grazed knuckles), grease it up with long life grease, and re-fit it, or you'll end up with the same problem again. I got into the habit of removing/greasing mine when I had the same problem a few years ago.
Old Jan 10, 2012 | 10:01 AM
stevieturbo
C**t
The key part of the lock will be broken where it pulls the steel rod.
Old Jan 10, 2012 | 10:32 AM
rog's Avatar
rog
Drive to a school, hang around and offer a child sweets to get in your car and into the boot to lower the seats, thats bound to work.
Old Jan 10, 2012 | 06:26 PM
lynnsy's Avatar
lynnsy
Cannot get to boot via the arm rest hole. Gonna try the speaker. There 6x9s and are probably screwed down (Hopefully)
Ill see how I get on lol
Old Jan 10, 2012 | 06:40 PM
stevieturbo
C**t
you reach through the arm rest and pull the rear seat catches. Or just force a rear seat forwards to get access to the catch then get into the boot.
boeb
Jan 9, 2020 05:11 AM
tankybaby66
Feb 6, 2016 02:24 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
gingeRS
17
Oct 2, 2015 09:42 AM
