Installing Rear Beam Bushes
Trying to install the large main bushes into the rear beam of a 2wd saph, has anyone got any good tips? We've done it twice before with a fence post between the beam and a roof joist and a trolley jack underneath but it wont seem to work this time. The other times we have used poly bushes and this time its a pair of original rubber mounts adn we got the 2 ton trolley jack on its limit! Any help would be good
Thanks
Thanks
tried fairly liquid, grease and spit!!! alot of people have put them in with the weight of the car but my dad has a whole new beam hes built up ready to swap with the one on his car so we want it all done before we take the old one off
Copper grease the bush and threaded bar with plate on 1 side and big washer on the otherside bolt it together to pull the bush into the beam and when it's tight hit bar with a hammer.
I didnt find them any worse than the poly ones i took out, nowhere near as bad as i thought they would be,
the handling was totally different though, so planted.
http://www.shop.motorsport-developme...h-yb-932-p.asp
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
