Fitting boost gauge?
Old Jan 8, 2012 | 11:55 AM
vroomtshh's Avatar
vroomtshh
Default Fitting boost gauge?
My boost gauge has a 4mm dia fitting on the rear of it. My boost gauge nipple on my egr pipe is 6mm. Can I get an adapter and use 6mm and 4mm hose, or will 4mm vac hose stretch over the 6mm fitting
I take it using 6mm hose would be no use as it will be too loose on the gauge?
Old Jan 8, 2012 | 12:31 PM
neil73's Avatar
neil73
I used 4mm silicon hose on mine and it went on the 6mm outlet fine, not sure about rubber hose though
Old Jan 8, 2012 | 12:45 PM
G420 DEL's Avatar
G420 DEL
cup of boiling water, dip 4mm hose in it till soft and supple, push on 6mm fitting.. simples
Old Jan 8, 2012 | 12:49 PM
vroomtshh's Avatar
vroomtshh
Cheers, will give that a go
Kyle Langford
27
Aug 5, 2019 07:54 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
mrmann
Aug 20, 2015 11:24 PM
no1trancefan
Ford Focus ST
Aug 7, 2015 09:21 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
