Air in fuel tank?
Old Jan 8, 2012 | 11:32 AM
Jasoncmor's Avatar
Jasoncmor
Default Air in fuel tank?
Hi all.
I have a mk4 fiesta 1.25, and every time I go to fill up with petrol, there is a build up of air in the tank, it releases every time I take the cap off.
Just wondering weather it is normal or not?
Cheers, Jason
Old Jan 8, 2012 | 11:37 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
are you sure its not sucking in when you take the cap off? as ive had it when the tank breather gets blocked
Old Jan 8, 2012 | 11:40 AM
Jasoncmor's Avatar
Jasoncmor
I'm not sure, it does sound like its built up air pressure being released when I take the cap off, how would I know if its sucking air in?
Also, the filler cap becomes hard to unlock, every time I take it off, though sometimes its not as bad as other times.
Thanks.
Old Jan 8, 2012 | 11:52 AM
clarke5700's Avatar
clarke5700
Thanks.
stick your hand round it when you take the cap off and try to feel what way the air rushes.
when my tank breather got blocked on my fiesta si i filled the tank up and when the fuel got low it cut out due to an air lock in the tank lol. when i took the cap off the fuel tank made a funny noise where it was poping back to shape after imploding lol
Old Jan 8, 2012 | 12:10 PM
DazC's Avatar
DazC
It's not air it's vacuum. It's the sound of air rushing in to fill the void. When the fuel is pumped out of the tank it is usually replaced by air that is drawn in through the breather. When the breather gets blocked air can't get in the tank to replace the volume of fuel that has been pumped out.
Think of you drinking from a bottle of coke. If you don't take your mouth away from the bottle to let air back in, the bottle starts to collapse in on itself as you drink more and more from the bottle. The same happens to the tank but the tank is a lot more rigid in construction so fights the vacuum more.
Old Jan 8, 2012 | 03:09 PM
Jasoncmor's Avatar
Jasoncmor
Thanks for alll your replies.
So how do I check, clean or replace the fuel breather?
Where is it located?
Cheers, Jason
Old Jan 11, 2012 | 07:42 PM
Jasoncmor's Avatar
Jasoncmor
Anyone?
Old Jan 11, 2012 | 07:59 PM
cossiestu's Avatar
cossiestu
I'm no expert, but always assumed the breather is the small hose that runs parralel with the filler pipe.....?
Old Jan 11, 2012 | 08:02 PM
andi-p's Avatar
andi-p
Are the fuel caps not vented? When I removed the tank out of my mk4 fiesta I dont recall seeing a breather.
Old Jan 11, 2012 | 09:18 PM
cossiestu's Avatar
cossiestu
Doesn't the vent exit back into the filler pipe, just by the top of the filler neck? (Well above the tank level)?
Old Jan 11, 2012 | 09:23 PM
andi-p's Avatar
andi-p
Wish I hadn't binned my tank out of mine I could of checked.
Old Jan 11, 2012 | 10:20 PM
Brendan's Avatar
Brendan
struggling with reality
THE filler pipe to the tank is split into 2 parts so it can be filled more efficientlyso the air comming out of the tank can escape fore easily rathe than come through the petrol you are pumping in! not sure about breather though. my wifes 1.25 mk 4 used to do the same and wee never had any probs!
Old Jan 11, 2012 | 10:25 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Every single fiesta I've come across has done this.
Old Jan 11, 2012 | 10:59 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Older cars had a small vent hole in the filler cap. After that, they had a vent pipe that vented underneath the back of the car. They then went to a vent pipe from the tank (or filler neck) cannister in the engine bay to absorb the vent gasses, which is then purged into the intake system when the car is started. I think they introduced the cannister system about the time cats became standard, so around 1993.
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
markk
Sep 9, 2015 08:11 AM
kevin36
Sep 8, 2015 12:23 PM
