mk1 sierra pinto anti theft
Old Jan 7, 2012 | 10:33 PM
kevhp171's Avatar
kevhp171
Default mk1 sierra pinto anti theft
hiya ive just bought a mk1 pinto sierra it has no alarm or immobaliser and i was wondering what i can do to stop or make it harder for someone steel it until i save money for an alarm as its parked on the street at night
any help would be great
Old Jan 7, 2012 | 11:47 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Take the ECU out?
Old Jan 8, 2012 | 12:24 AM
JFB Tech's Avatar
JFB Tech
Not entirely sane
A Mk I Pinto won't have an ECU. Easiest way would be to fit a battery disconnector. They have a thumbscrew which you undo to electrically disconnect the battery. You can also get them with a fuse link to keep radio memories and clocks etc. going. If you tried to start the car with just the small fuse link it would blow the fuse instantly.
Old Jan 8, 2012 | 01:29 AM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Ignore me then! Was just saying that as it's what I'd do with mine lol.
Old Jan 8, 2012 | 09:16 AM
R4N SS's Avatar
R4N SS
Fit a fuel cut off switch and hide it inside the car cost about a fiver In total
Old Jan 8, 2012 | 10:57 AM
kevhp171's Avatar
kevhp171
cheers for the info how easy is it to fit a fuel cut of switch and wheres the best place to buy one
Old Jan 8, 2012 | 12:09 PM
martysmartie's Avatar
martysmartie
It most likely does not have a electronic fuel pump, pretty sure it will be mechanical!
Personally I always err on the physical security side, as it will detter thiefs as well!
So a disc lock for example and a handbrake gear lever lock, only other thing you can do is have a alarm/immobilser system fitted, you need something though as security on them isn't a strong point!
If wanting a cheap/easy DIY option then you can fit a cut off to the ignition system!
Martin
Old Jan 8, 2012 | 12:17 PM
R4N SS's Avatar
R4N SS
I'm pretty sure it don't matter if it's elec or mech fuel pump as on old neighbour had this cut off switch on an old Morris minor and that saved it from being driven off - car only got a hundred yards before the fuel ran out in the pipes and would not start again so the thief legged it. The old boy jumped in, flicked a switch and parked it back outside his house
Old Jan 8, 2012 | 01:47 PM
martysmartie
It does, Morris Minor has an electric fuel pump (SU to be precise) thus you can cut the power to it, mechanical fuel pumps are as the name suggests, i.e. driven from the engine, therefore there is no power to cut!
Martin
Old Jan 8, 2012 | 02:03 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
Had a removable stereo in an old mk3 escort van that I put a Microswitch at the bottom of its cage,microswitch was wired into ignition system so when stereo was out van was imobilised
Was hard to see so no-one ever knew.
Old Jan 8, 2012 | 03:40 PM
Char1ie's Avatar
Char1ie
Take the steering wheel off?
Charlie
Old Jan 8, 2012 | 04:07 PM
boy-racer-1's Avatar
boy-racer-1
put it this way cut off switches and feul pump switches etc wont do much if a professional car theif wants your car he will have it and no doubt come prepared to steal it, yea switches will stop little idiots from taking out for a joy ride as they probably wouldnt know how to make a home made ignition loom that goes to the 2 plugs behind the dashboard and all they will know is how to cut a few wires about and break a steering lock, best thing you can do everynight is what i did, put your steering full lock to 1 side which will help stop if someone tried to use a toe truck to take it away and pull the lead off in the middle of your dizzy cap every night, or take the plug off of your ignition amplifier a bit so its not noticeable that its actually disconnected, that way, it cant be started and you will hear the silly theif trying and trying to start your car and no doubtedly wake you up before he figures it out and is off with your motor, dont know about you but my car was always parked on my drive with my window open a tad and my car made some noise when being started
Old Jan 8, 2012 | 04:15 PM
gouch1's Avatar
gouch1
cut off switch and a padlock and chain round the break pedal to the sterring wheel
Old Jan 8, 2012 | 06:56 PM
nicksaph's Avatar
nicksaph
the fuel cut off thing is possable even if its a early carb model car,.
you could fit a tap in the fuel line under the bonnet, switch the tap off and no fuel
or there was a company a few years back that did a electric fuel cut off valve. same princable as above but the tap had an electric solinoid in it and a switch in the car
cheeRS nick
rex647
Mar 6, 2022 06:20 AM
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
chowfornow
Sep 19, 2015 10:47 PM
steff19
Escort Range
Sep 9, 2015 10:14 PM
Adam Graham
Sep 6, 2015 06:04 AM
